Results 1 to 9 of 9
Thread: ABS for solar collectors
Hybrid View
    DIY Junior Member kjkrum's Avatar
    May 2012
    Tucson, AZ
    Default ABS for solar collectors
    I've read some sites that say never to use ABS pipe for solar collectors, because it's damaged by UV. (But so is PVC and polyethylene.) And other sites specifically recommend ABS for their collector designs.
    Has anyone here ever used ABS? What was your experience?
    swimming pool solar heaters are ALWAYS ABS. Unless you are making your own collector, you will buy whatever the manufacturer produces, but get a good warranty with it.
    May 2012
    Tucson, AZ
    I am planning on building my own. It'll supply our showers and sinks.
    Jun 2009
    Canada
    Do you have ABS vents sticking out of your roof?
    Go look at them, and you'll see why it isn't recommended.
    May 2012
    Tucson, AZ
    I do, but they've been painted. Enlighten me?
    Edit: And what would you recommend instead of ABS - black or painted PVC? I know copper would be ideal, but I can't afford it.
    Edit2: For blackening the collector, I'll also be experimenting with laser toner. I have about a half gallon of the stuff left over from another mad science project. It's basically nanoscale carbon particles coated in wax or polymer, which become adhesive when warmed. It's so black that it's hard to look at. I need to experiment with applying it to different materials and testing its long-term durability in the sun.
    In the trades Dana's Avatar
    Jan 2009
    Like PVC, ABS has to be de-rated for pressure at elevated temperatures. Pool heaters are pretty much at atmospheric pressure, and run at fairly low temps, but in some other solar heater you could get a lot of deformation (or a superheated shower, or a steam exlposion) with 200F+ stagnation temps and 50psi system pressure.
    For drainbacks/drain-downs running at atmospheric pressure you can probably run it at 180F without much of an issue, but not a whole lot higher.
  1. Solar Hot air
    By Semon in forum Solar and Geothermal Water Heating Forum
    Last Post: 02-13-2012, 06:18 PM
  2. Solar Hot tub
    By Scuba_Dave in forum Solar and Geothermal Water Heating Forum
    Last Post: 07-28-2010, 08:16 PM
  3. Solar looks complex…but not if you have help.
    By alexcruz8ac in forum Solar and Geothermal Water Heating Forum
    Last Post: 06-25-2010, 07:06 PM
  4. Any NEC collectors out there?
    By Mikey in forum Electrical Forum discussion & Blog
    Last Post: 09-07-2008, 04:25 PM
  5. solar pump
    By kinghan08 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-04-2007, 07:12 AM
