Results 1 to 6 of 6
Thread: Which pipe for sewer line
    DIY Junior Member diganddig's Avatar
    Apr 2012
    Calgary Alberta Canada
    Default Which pipe for sewer line
    Hello
    I'm in Calgary Alberta. I need to replace my sewer from the house out to the City service - around 8' deep. Should I use 4" ABS-DWV Schedule 40 Cell Core pipe? Or should I be using 4" PVC Solid Wall DR 35? Or something else?
    Jan 2008
    What do they use in your area for new construction? Cast iron or solid core PVC is common here.
    It depends on what is "used" in your area. Here, it would be almost exclusively ABS pipe and fittings. Other areas use PVC, and still others may have a 50/50 mix depending on the plumber's preference.
    we use DR35 PVC sewer pipe for the main
    DIY Member Willie Two's Avatar
    Jan 2011
    British Columbia
    Why do we Canadians use PVC Sch 35 vs ABS Sch 40 pipe. Is it cost ? Material flexibilty / frost or is it just better ?
    Yakima WA
    Willie, I don't know that it is a "Canadian thing" at all. The choice of materials will vary from place to place here in the States too. Some areas don't stock ABS at all, other places use ABS 100%. Go figure.
  1. Water Line Inside Sewer Pipe
    By rugoofy in forum Illinois Plumbing Code Questions
    Last Post: 05-30-2011, 08:38 PM
  2. Condensate Line to Sewer Pipe, NSPC
    By PrezMFL in forum NSPC Plumbing Code Questions
    Last Post: 06-07-2010, 08:55 AM
  3. Condensate Line to Sewer Pipe, NSPC
    By PrezMFL in forum Plumbing Forum Discussion & Blog
  4. Sewer line pipe size
    By Terry in forum Plumbing Forum Discussion & Blog
    Last Post: 06-07-2005, 02:16 PM
  5. Sewer line to city line (sewer lateral) question r/o
    By H20Melon in forum Plumbing Forum Discussion & Blog
    Last Post: 02-11-2005, 05:12 AM
