Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Wiring an Electrical Outlet to Pump Pressure Switch
    DIY Junior Member asmart82's Avatar
    Jan 2011
    East Orlando FL
    Default Wiring an Electrical Outlet to Pump Pressure Switch
    If I have a 3-wire pump, where would I connect the wires for the outlet inside the pressure switch so that the outlet only has power when the pump is on or would I be better off wiring it to the control box?
    Mar 2011
    Houston, TX
    Quote Originally Posted by asmart82 View Post
    120v or 240volt outlet.
    It can be done but may not be safe, and may not meet code.
    What is this Outlet going to be used for ?
    Jan 2011
    East Orlando FL
    I believe it is 240v, not sure but I can check. The outlet is going to be for a Stenner Chlorine pump.
    I had the pump hooked directly up to the pressure switch but I would prefer to have it hooked to an outlet and I prefer not to buy a flow switch.
    Here is a diagram for what I am trying to do but I am not sure which wire is which in the diagram. http://www.cleanwaterstore.com/techn...or_startup.pdf
    Mar 2011
    Houston, TX
    All of the needed info is in the PDF file.
    It would connect to the same output / switched connections on the pressure switch as your Well Pump.
    If you do not understand the info in your PDF file then you may want a professional to help you.
    Be careful playing with electric.
    Jan 2011
    East Orlando FL
    I've got the outlet hooked up. The chemical pump works only when the well pump is on but the power alternates on and off randomly for the chemical pump. Any idea what might be causing this? When I hook the pump up to a normal outlet, it is always on as it should be.
    Mar 2011
    Houston, TX
    If it is not wired to the proper voltage it may be tripping the pumps internal overload protector.
    Jan 2011
    East Orlando FL
    You were correct. It was a 120v pump on a 220v outlet. Bought a 220v motor and it fixed the problem. Thanks!
    Mar 2011
    Houston, TX
    Nice that you got it working.
    Enjoy.
    Moderator valveman's Avatar
    Mar 2006
    You could have made the 115 volt pump work. Just needed one wire to the pressure switch and the other to ground.
    Mar 2011
    Houston, TX
    That is what I would have done. Or run a new wire with a neutral.
    But to meet code it would have to be connected to a neutral, because it would be a current carrying conductor.
    Mar 2011
    Long Island, NY
    Don, NO, I don't think you would have connected that wire to ground. I don't know why you even joked about it.
    Mar 2006
    Doesn't the neutral go to the ground bar? Or am I mistaken?
    Mar 2011
    Long Island, NY
    Yes, (at the service panel) and that's the ONLY place where they are in effect connected to each other.
    Mar 2006
    Quote Originally Posted by BobL43 View Post
    Thanks Bob!
    Mar 2011
    Houston, TX
    I was not joking.
    That is how my 120V heat tape gets power from my Well pump switch for the winter.
    It may not meet code but it works for whatever I want to plug into the 120V outlet.
    Code is for City Slicker folks. We just Git-R-Done on the City Slicker Farms in Texas.
  1. pressure switch wiring please help
    By brenjake in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-07-2011, 03:04 AM
  2. wiring 220V Stenner pump to pressure switch
    By Flipperman2a2w in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-28-2011, 07:29 AM
  3. Replies: 17
    Last Post: 01-24-2011, 08:44 AM
  4. electrical contacts on Pressure switch
    By mrspaceman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-04-2009, 12:43 PM
  5. Electrical outlet question
    By brosnt1 in forum Electrical Forum discussion & Blog
    Last Post: 01-14-2008, 04:04 AM
