Results 1 to 3 of 3
Thread: TSU33A Fill Valve for E-Max TOTO
    Default TSU33A Fill Valve for E-Max TOTO
    One of the fill valves used in the Eco TOTO is the TSU33A
    One thing to check if it's not shutting off is the pull-out screen at the inlet of the valve.
    The screen in the inlet. A needle nose pliers will remove it for cleaning.
    The TSU33A fill valve
    DIY Junior Member brifro's Avatar
    Dec 2013
    edgewood, ky
    I have this valve in my Toto. Is there any other fix for it besides the filter if it keeps running? Also, what is the slotted turn adjuster for (on top of the unit; it has + and - on it)? Thanks.
    This valve has a screw adjustment for water level.
    You can't take this valve apart. If cleaning the filter doesn't do it, the other option is replacement.
    I like the Korky MaxPerformance fill valve.
  1. Toto flapper and fill valve
    By dotil in forum Toilet Forum discussions
    Last Post: 07-31-2009, 05:59 AM
  2. Toto Fill Valve Problem Continues G-Max valve with adjusting screw
    By levitonski in forum Toilet Forum discussions
    Last Post: 12-02-2008, 12:40 PM
  3. Toto TSU07A.5 fill valve not stopping
    By supun in forum Toilet Forum discussions
    Last Post: 08-01-2007, 10:16 PM
  4. Toto Leaky Fill Valve
    By wtreedy in forum Toilet Forum discussions
    Last Post: 12-08-2006, 09:23 AM
  5. Toto fill valve leaking?
    By rockjet in forum Toilet Forum discussions
    Last Post: 07-03-2006, 04:28 AM
