Results 1 to 2 of 2
Thread: Laminate Countertop Replacement
    DIY Junior Member Fishin's Avatar
    Dec 2009
    Va
    Default Laminate Countertop Replacement
    I want to replace my u-shape laminate kitchen countertops. What's the going trend? Is using preformed countertops with 45 degrees already cut OK? I suspect having a cabinet shop fabricate a large u-shaped countertops would be quite costly but I may do that if exposed cuts are definitely a bad idea. Thanks for your input.
    IT is impossible to fabricate ANY ""U" shaped, and most other shapes for that matter, without seams. Some materials, such as granite and Corion, can be finished so the seams are either invisible or barely detectiable. Laminate countertops will always have visible seams.
  1. Best Vacuum for Laminate floor?
    By Mike50 in forum Remodel Forum & Blog
    Last Post: 03-16-2007, 09:26 PM
  2. Laminate Countertop DIY
    By Lakee911 in forum Remodel Forum & Blog
    Last Post: 07-26-2006, 10:51 AM
  3. Laminate wood
    By Cookie in forum Remodel Forum & Blog
    Last Post: 06-25-2006, 06:55 AM
  4. Raw edge of laminate countertop
    By DaveT in forum Remodel Forum & Blog
    Last Post: 08-27-2005, 05:32 PM
  5. Laminate surrounds
    By Jabela in forum Shower & bathtub Forum & Blog
    Last Post: 06-21-2005, 09:55 AM
