Results 1 to 5 of 5
Thread: Identifying Cartridge, Moen 1200
    DIY Junior Member kalisti's Avatar
    May 2012
    California
    Default Identifying Cartridge, Moen 1200
    Hello,
    I'm a total novice at this, but am having difficulty replacing a leaky shower faucet. It is a single faucet, pulls out to go on, turns to hot/cold. I had difficulty getting it out, but eventually was able to pull it straight out, after spraying some stuff in to remove build-up. I'm not positive I got everything out, but it seems like I did.
    I brought the cartridge into my local hardware store to get a replacement, and he couldn't identify it. I was hoping someone here could help me. The cover says Moen on it, but there is no part number or identifier on the cartridge.
    Any help would be super appreciated! I'd love to be able to do this myself, but am at a bit of a roadblock.
    Moen 1200
    I'm guessing you have an old brass one. The outer shell is still stuck in the valve?
    Below is the 1225B that is mainly plastic.
    Plumber jimbo's Avatar
    With all due respect.....anyone working in the plumbing department of any store that does not recognize the inner stem of a Moen 1200.........sheeeeeesh!!
    As Terry said, replace it with the 1225.
    Your hard chore now is getting the main part of the cartridge out. The hardware stores have the moen removal tool. Check back with us if you have trouble. You WILL have trouble!
    May 2012
    California
    Thank you! Yes, it is mostly brass, which confused me when I went in to find a replacement. I saw the 1225 there and thought that would be the one I should get, but the plastic housing confused me. The tool the guy sold me just fit on to this and pulled it straight out. It was metal, with a single crossbar. Is there an additional tool I can use to get the stuck part of the cartridge out?
    May 2012
    California
    Just to clarify:
    This is the tool I have: http://www.homedepot.com/webapp/wcs/...6X-_-202998692
    But I have a problem, because the part that screws in to clamp down is too small to fit over the pipe (my fixture is inset), so I can't seem to get any traction. Is there an alternative way to get the remaining part of the cartridge out?
  1. Identifying Tub Shower cartridge, Source for the BNK7005
    By Old man in forum Shower & bathtub Forum & Blog
    Last Post: 05-15-2013, 03:32 PM
  2. Moen 1200 cartridge - can I just replace the rings??
    By nards01 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-27-2012, 05:14 AM
  3. Need Help identifying cartridge
    By waynevpearson in forum Shower & bathtub Forum & Blog
    Last Post: 08-16-2010, 08:37 AM
  4. Need help identifying a Moen 1200 shower valve/cartridge
    By sproksch in forum Shower & bathtub Forum & Blog
    Last Post: 04-22-2010, 12:21 PM
  5. Need help identifying a cartridge.
    By daphotoguy in forum Shower & bathtub Forum & Blog
    Last Post: 07-18-2005, 09:42 PM
