Results 1 to 8 of 8
Thread: Help! old shower valve, unknown design/manufacturer
    DIY Junior Member JB_1024's Avatar
    May 2012
    California
    Default Help! old shower valve, unknown design/manufacturer
    Hello,
    I've got a leaky shower valve here of unknown manufacture. No names or part numbers on it. Pulled out the cartridge and the design is nothing like what is currently available, so my question is A) can I get parts for this, or B) can I put a newer-design cartridge in the valve body? Please see attached photos...
    -JB
Size:  40.8 KBName:  02.jpg
Size:  44.1 KBName:  04.jpg
Size:  48.1 KBName:  05.jpg
Size:  49.5 KBName:  06.jpg
    Aug 2009
    South*East
    A picture of the trim may help.
    John
    May 2012
    California
    Trim has no names on it either. Has mounting screws at 4:30 and 7:30 positions...Name:  trim.jpg
    1; You can only get parts if you can identify the manufacturer. The "snap on" balancing spool would make it easy to identify, but it also means that it matches none of the "standard" mnanufacturers.
    2. There are no "generic" cartridges that will interchange between brands.
    The stem looks like it could be a Valley, but I am not sure if they made a pressure balanced valve that looks like that.
    Looking at where the rear seals go in the valve body, it looks like that area is rough...unless that can be cleaned up, I'm not sure any cartridge will seal or last long if it did. I'm assuming (and may not be right) that the inlet to the cartridge must seal against the rear seats.
    Plumber jimbo's Avatar
    I agree with hj that the trim, the spool connection, everything...is reminiscent of Valley, except the inner dog leg. I can not find any valley cart. that looks like that. I guess the one more thing we would like to see is the handle.
    May 2012
    California
    Hello again and thanks for the replies. I bit the bullet and just replaced the whole valve. What was supposed to be a 5-minute thing turned into a whole weekend - as usual.
    Jimbo: the handle was missing to begin with, that's what started all this. Since I could not find a knob to fit it, I figured I'd just pull the whole cartridge and take it to the local plumbing shop. Nobody there had ever seen one like it! I put it back in and it was leaking horribly...
    All good now though, and the family is happy with the new valve because it has pressure-balancing and all that.
    -JB
    We appreciate the follow up. We will file this one in the "cold case-stumped" folder!
  1. Which Manufacturer?
    By wagoneer89 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-30-2010, 11:44 AM
  2. Pex to Kohler 6 port Thermostatic Valve and general design q's
    By ijs12fly in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-05-2009, 05:22 AM
  3. Handheld Shower/diff manufacturer valve and Trim
    By nmchugh6 in forum Shower & bathtub Forum & Blog
    Last Post: 12-19-2008, 05:31 PM
  4. Why does the Manufacturer say this?
    By edwardh3 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-14-2008, 09:06 AM
  5. Unknown toilet manufacturer
    By angelabakita in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-19-2007, 10:31 AM
