Results 1 to 5 of 5
Thread: Subpanel in attached garage adjacent to living space
    DIY Junior Member Widgelet's Avatar
    May 2012
    Bothell
    Default Subpanel in attached garage adjacent to living space
    I'm adding a subpanel in an attached garage, adjacent to living space, a common wall. I'm in unincorporated Snohomish County.
    what are the rules regarding placing a subpanel in an attached garage, in or on a common wall with adjacent living space?
    Pretty much the same as a subpanel placed anywhere. Some, but by no means all: fed with a four-wire cable, neutral and ground bus bars separated, access space in front, above, and to the sides (don't remember the numbers).
    Jun 2007
    North Carolina
    Pretty much the same as a subpanel placed anywhere. Some, but by no means all: fed with a four-wire cable, neutral and ground bus bars separated, access space in front, (36 inches) above,(6 1/2 feet) and to the sides(30 inches) (don't remember the numbers).
    yes you do see it is in red
    Sep 2009
    Seattle. WA
    There may be a fire rating requirement on that wall. I'm sure your county building officials stand ready to answer your questions on that subject.
    If the wall between the garage and the house is a firewall (likely unless it is really old), then you may want to surface mount it rather than install flush (in the wall) mount. You need to be careful about the wire penetrations in the wall to maintain a fire rating as well. How you do that can get more involved.
  1. Laundry Room. Sink and Washing machine on adjacent walls with stack at corner
    By bryankloos in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-02-2012, 07:10 PM
  2. Building extra room in attached garage.
    By la Vasca in forum Remodel Forum & Blog
    Last Post: 05-31-2011, 05:46 PM
  3. Bathtub water is damaging adjacent wall
    By GregN31 in forum Shower & bathtub Forum & Blog
    Last Post: 03-08-2011, 03:43 PM
  4. Ok to extend bathroom circuit to power tv on adjacent wall
    By PabNYC in forum Electrical Forum discussion & Blog
    Last Post: 03-25-2009, 07:39 PM
  5. Positive airflow out of condensate drain into living space
    By ltm in forum HVAC Heating & Cooling
    Last Post: 11-20-2008, 08:31 PM
