Results 1 to 3 of 3
Thread: Do I need to extend cleanout above floor?
Hybrid View
    DIY Junior Member steve-c's Avatar
    May 2012
    Bellingham, WA
    Default Do I need to extend cleanout above floor?
    Hi - We're building our own house and I'm doing the plumbing, UPC is the code here. The drain line (3") runs 22 feet in a straight line from the end to where it exits the foundation. According to my code booklet, since the distance is >20 feet, I need to extend the cleanout outside (not possible) or up above floor level (no good place for it there). My question is this: can I avoid extending the cleanout to the floor level if I put a 2-way cleanout at the exterior end of the drain line?
    Thanks for any help on this. If I had the money I'd hire a real plumber...
    Steve
    Sep 2009
    Seattle. WA
    Not too sure what you're asking here: an "approved" exterior 2-way cleanout, extended to grade, can substitute for the otherwise required upper terminal C/O, but that's not
    such a good idea, I think. The only 20-ft rule I know of is a maximum distance of underfloor C/O opening from access hatch, crawl hatch, etc.
    May 2012
    Bellingham, WA
    Thanks for your reply. The end of the run is 22 feet from the crawl access. The way I read it my options are to either extend the pipe outside or up to floor level. Running it outside would be a big big job and there's no good place to hide a cleanout cover in the floor above. If I can get away with a 2-way cleanout at the outside edge of the foundation where the pipe exits that would be good. The pipe is only a foot or so below grade there so it'd be easy to use.
    Steve
  1. How to extend a CO?
    By DavidTu in forum Plumbing Forum Discussion & Blog
    Last Post: 02-02-2011, 02:16 PM
  2. Floor Cleanout?
    By supermattthehero in forum Plumbing Forum Discussion & Blog
    Last Post: 02-09-2010, 02:12 PM
  3. Brass Cleanout Plug in ABS Cleanout Tee?
    By Shinshi in forum Plumbing Forum Discussion & Blog
    Last Post: 02-09-2009, 05:03 AM
  4. Watts Adjustable Floor Cleanout
    Last Post: 01-26-2009, 09:32 AM
  5. Basement Floor Cleanout
    By Scott Alger in forum Plumbing Forum Discussion & Blog
    Last Post: 02-20-2007, 08:52 AM
