petegerster
I am in the process of gathering the materials to replace my jet pump with a submersible. My well has a 6 inch inside diameter. It is about 140 ft deep and the water surface level (with no pumping) is about 25 ft below the surface of the ground.
I intend to fabricate and install a shroud on the, yet to be delivered, 7GPM 1/2HP Gould pump model 7GS05422C. I have been unable to locate the recommended 4" PVC (astm 2729) thin wall sewer pipe. I can get 4" HDPE pipe (astm F 810). Can anyone advise me whether the HDPE pipe is a suitable replacement for the PVC? From what I have been able to find, the wall thickness of the HDPE is greater and the inside diameter appears to be about 1/8 inch. less.
I am concerned:
(1) about the decreased area of the annulus around the pump through which the water would be forced to flow
(2) whether the thicker HDPE material is too heavy to work with.
Thank you.
I am concerned:
Thank you.
