Results 1 to 6 of 6
Thread: Price Pfister - Single Push/Pull Shower stem valve
    DIY Junior Member richard8's Avatar
    Oct 2008
    Washington
    Default Price Pfister - Single Push/Pull Shower stem valve
    Hello,
    Does anyone know the process or instructions to remove this item.
    I believe it is an Avante model from price pfister.
    I do not want to cause damage to piping behind the tile wall surface.
    Do I need to remove any clips.Name:  price_1.jpg
Size:  32.5 KBName:  price.jpg
    Thanks for any information or advice.
    richard8
    Plumber jimbo's Avatar
    That outer ring is the retainer. It needs to be unscrewed. You have a lot of deposits, so you will need to soak with vinegar and proceed carefully.
    Unscrew the cap. Put the screw back into the stem. Then grab it with a pair of pliers, push the stem in and they YANK it out hard and quick. You will probably have to repeat the "push/pull" a few times but it will come out.
    Oct 2008
    Washington
    Do you use vinegar for soaking the stem portion.
    Then use something else for the threads.
    People are paying me for my time, so I do NOT soak anything in vinegar or anything else. Remove the cap, pull the cartridge, put in the new one, and make out the bill.
    Oct 2008
    Washington
    Default soak with vinegar
    hello,
    Do you soak the portion inside the valve with vinegar. What about the theads.
  1. Price Pfister Avante. How to remove a stem from shower?
    By templeavenue in forum Shower & bathtub Forum & Blog
    Last Post: 08-16-2013, 01:04 PM
  2. single handle price pfister shower faucet
    By don640 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-06-2008, 07:37 AM
  3. Replies: 1
    Last Post: 10-28-2007, 04:01 PM
  4. American-Standard push/pull tub and shower valve
    By paljoey in forum Shower & bathtub Forum & Blog
    Last Post: 10-01-2007, 05:30 AM
  5. Price Pfister Single lever shower NO COLD!
    By andysaul@aol.com in forum Shower & bathtub Forum & Blog
    Last Post: 08-06-2007, 06:51 AM
