Results 1 to 10 of 10
Thread: Scalding Water Coming From Cold Side of Faucet
    DIY Senior Member Kiko's Avatar
    Jul 2009
    Royal Oak, Michigan
    Default Scalding Water Coming From Cold Side of Faucet
    My parents have a hansgrohe widespread roman-style lavatory faucet in their master bath. They have always had a problem with scalding hot water coming out of the cold side of the faucet. After about 20 seconds, the water would turn cold. Now, however, the problem has become much worse. The scalding water continues for 2 minutes or more, before it becomes cold. Once it is cold, it stays cold, until the hot water is used. Then the cold becomes hot again, after both the hot and cold are turned off for a while.
    Anyone have any ideas what could be causing this?
    If they have a hot water recirculation system, the check valve is probably shot. Depending on the system, if there's a valve under the vanity for the recirculation system, it may need replacement.
    Or, there could be a defective cartridge somewhere that is creating a cross-over.
    Jul 2009
    Royal Oak, Michigan
    They don't have any hot water recirculation system. However, that is the same bathroom that has the hansgrohe thermostatic shower cartridge that has been acting up.
    That shower also has scalding hot water coming out of the cold side for a minute, before it turns cold. Then, you can't get anything out of the shower except luke-warm water, regardless of the position of the temperature control knob on the handle.
    What I don't understand is how can that shower cartridge cause scalding hot water to come out of the cold side of the lavatory faucet, when you can't even get hot water to come out of the shower, except for a few seconds when you first turn it on?
    Some cartridges when they fail connect the hot and cold water together - i.e., a cross-over. If there's a small pressure difference, when you turn on a faucet, it can flow one way or the other.
    Home Builder ckl111's Avatar
    Apr 2009
    Ontario
    thermostatic valves are mixing valves so they will alter the flow of hot and cold water automatically. The faulty valve must be allowing hot water to back flow into the cold water line instead of mixing the water towards the shower head.
    Jul 2009
    Royal Oak, Michigan
    Thanks Jad and Ckl!!
    So, I guess all the hot water that I'm not getting out of the shower is ending up in the cold water line.
    I've actually tried to remove that cartridge, but it is very frozen. You have to use a huge crescent wrench as a counter-wrench, while you unscrew the cartridge from the housing. I'll try squirting on some PB blaster, unless someone has a better idea.
    The majority of thermostatic valves have integral check valves to prevent the water from going into the system and affecting other faucets, so that may NOT be your problem. BUT, only a plumber, on site, may be able to diagnose what the REAL problem is. WE can only guess using YOUR information, which may not be completely correct.
    Plumber jimbo's Avatar
    With no recirc system, it is NOT common for hot to cross over to cold. It is more common for cold to cross over to the hot side. Someone needs to see your system/
    Jul 2009
    Royal Oak, Michigan
    The tech-support manager at HG told me that it was impossible for their cartridge to cause the kind of cross-over situation I described. But before we hired a plumber, I decided to try to troubleshoot this myself. I followed the cold pipes starting at the meter, feeling them whenever they were visible, and the same thing for the hot pipes, starting at the HW tank.
    The closer I got to that shower, the warmer the cold pipes were. And behind the shower access panel, the hot and cold were the same HOT temperature. As I ran the shower, the cold shower supply got colder and hot got hotter. But, when I shut off the shower, the cold instantly became just as hot as the hot. So, I knew the cartridge was at fault. I replaced the cartridge and there's no more cross-over. And the shower works perfectly again.
    Thanks for all your suggestions.
    Apr 2009
    Ontario
    Glad it worked out for you. To quote Sherlock Holmes, "When you have eliminated the impossible, whatever remains, however improbable, must be the truth".
    If the hot and cold lines were reverse during installation, the water would ALWAYS be reversed. The cold lines would not be getting variably hot and cold. Without a recirc system, what else could it have possibly been?
  1. Questions about how to repair Moen 8" offset sink faucet (cold side).
    By lee_leses in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-26-2011, 10:59 AM
  2. No cold water coming from my single handle Pfister lavatory faucet
    By anglii in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-08-2011, 09:45 AM
  3. Hot water at cold side all faucets
    By ben1111 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-23-2010, 06:39 AM
  4. Very little cold water coming out of shower.
    By Sorcha in forum Shower & bathtub Forum & Blog
    Last Post: 09-17-2008, 10:27 AM
  5. Hot water on cold side when pump on
    By wschmidt in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-21-2006, 07:20 AM
