Results 1 to 5 of 5
Thread: Bathroom remodel advice
    DIY Junior Member Brian.Hoard's Avatar
    Nov 2010
    Haymarket, VA
    Default Bathroom remodel advice
    Hello,
    I have our small second story bathroom gutted down to the studs and am ready to build it back up.
    I removed the old 60" cast iron tub that was in there as it was from 1973 when the house was built.
    The room is only 8'x5', and had a tub/shower toilet and sink. Now that I am starting over, what is the best quality to go with for the tub? I am using a Toto toilet, love those things. But as I read about bathtubs, I see about acrylic, cast iron, etc. It appears that definitely don't want fiberglass as I want to get the best quality surface that will last the longest so I won't be messing with this room for a very long time.
    Any advice for what I should look for, or any specific brands that you would recommend? I'm of the mindset that buying good quality is actually the most inexpensive in the long run. So I don't mind paying premium prices for quality. I'm just not sure about any of this when it comes to tubs.
    Thanks for any help.
    Jul 2009
    North Vancouver, BC
    You don't need steel or cast iron to have a quality tub. What is so important is that the tub is comfortable and has a base inside not prone to flexing.
    Get in the tubs at the showroom. Lie down. Get comfy if you can, if you can't ....... NEXT!
    JW
    Hi Brian,
    The most durable and longest lasting tubs are cast iron. Unfortunately, they are also the heaviest.
    John Bridge, Ceramic Tile Setter :-)
    http://johnbridge.com/vbulletin/index.php
    It's pretty tough to beat cast iron all right. They are a two man installation. You see them in old homes still being used.
    The order of preference for me;
    1. Cast iron
    2. Americast
    3. Any plastic tub
    4. WAY DOWN THE LIST, in last place, enameled steel
    Once you get past #2 the customer has to buy the tub, because I will not guarantee it.
  1. Pre-Remodel Advice Sought
    By larryleveen in forum Remodel Forum & Blog
    Last Post: 12-01-2011, 12:14 PM
  2. Replies: 11
    Last Post: 08-01-2011, 04:28 PM
  3. Shower remodel advice please!
    By ecu pirate in forum Shower & bathtub Forum & Blog
    Last Post: 05-14-2007, 11:07 AM
  4. Advice on vents in old-house bath remodel?
    By staceyneil in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-03-2007, 06:57 AM
  5. need advice remodel/termites?
    By Kat in forum Shower & bathtub Forum & Blog
    Last Post: 09-19-2005, 04:19 PM
