Results 1 to 2 of 2
Thread: Diverter or separate pipes?
    DIY Junior Member phillykitty's Avatar
    Apr 2012
    Philadelphia
    Default Diverter or separate pipes?
    Hi there everyone,
    I am in the process of building a bathroom on the third floor of my house. There wasn't a bathroom there before so I
    am not dealing with any existing plumbing issues.
    I was originally going to do a walk-in shower but a friend of mine who is an interior designer has convinced me that I should
    go with a tub as it will add to the resale value of the house. I have decided that she is right and will probably go with
    a Kohler drop in tub that has an integral tub flange.
    The problem is that I have already purchased the shower hardware and I can't return it. It is a Hansgrohe showerpipe with an exposed
    thermostatic valve. Plus I really like the look of it and want to use it.
    http://www.amazon.com/Hansgrohe-2716.../dp/B0016H7P9K
    So now that I have decided to use a tub instead I will have to have tub hardware. What is the best way to plumb this? It doesn't make sense to me to have a diverter from the bathtub faucet since the thermostatic valve is built into the shower pipe. Should I just tee off the hot and cold lines and plumb the bathtub hardware and shower hardware separately? Or is there some other solution that I am not thinking of. The idea of having the tub and shower supply lines separate from one another does not bother me. I would rarely use the tub anyway.
    Thanks in advance for any suggestions.
    DIY Junior Member StillGoing's Avatar
    Sep 2012
    Los Angeles
    If I spent over $1000 on a shower kit and couldn't return it I'd want to use it too. It's been a while since someone replied. Maybe there is a way to put a diverter into your shower pipe? If you did the job already what did you do?
  1. Supply Lines to Separate Showers
    By danboston in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-03-2011, 02:54 PM
  2. How to separate PVC pipes
    By mntentman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-01-2010, 06:21 AM
  3. Can I separate aan ABS fitting?
    By pjb in forum Shower & bathtub Forum & Blog
    Last Post: 03-14-2008, 04:48 AM
  4. Juncture of tub and separate shower
    By Access for All in forum Shower & bathtub Forum & Blog
    Last Post: 10-22-2007, 07:13 PM
  5. Shower valve with separate diverter valve question
    By remodelingit in forum Shower & bathtub Forum & Blog
    Last Post: 04-28-2006, 01:15 PM
