Results 1 to 3 of 3
Thread: location of water heater
    DIY Junior Member jcds's Avatar
    Nov 2012
    Manitoba
    Default location of water heater
    Is any one aware of any code requirements that would limit where i can locate a hot water tank. I am planning an addition of a bathroom in a small cabin that is going to get municpal service. No gas so I must go electric and I have no faith in the electric tankless. space is tight but i have just enough room in the bathroom beside the WC for the electric water heater. Is anyone aware of any Canadian (manitoba) code restrictions that would disallow that as a location.
    as a secondary question I need a tank that is narrow, like 18" or less any brands that jump to mind , most are 20 to 22 inches. I only need a 30 gallon or so.
    thanks for your input and advise
    30 gallon electric heaters are usually 18" in diameter, and an electric heater, because it does not use combustion air or create gases, can go anywhere you want to put it.
    Nov 2012
    Manitoba
    was hoping that was the case, will make my spring project a whole lot easier, thanks for the reply hj
  1. Optimal location for water heater?
    By dereks in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-07-2011, 05:45 AM
  2. Electric water heater location
    By chuck b in forum UPC Plumbing Code Questions
    Last Post: 01-30-2011, 05:00 PM
  3. What is needed for new water heater in new location?
    By alwaysfine in forum Water Heater Forum, Tanks
    Last Post: 12-11-2010, 06:49 AM
  4. Water Heater Location Question
    By PlumbBobSquarePants in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-23-2007, 06:55 AM
  5. Water Heater Location?
    By Michael McCann in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-26-2006, 08:39 PM
