Results 1 to 5 of 5
Thread: Water softener pellets vs. crystals
Hybrid View
    WaterManiac kwust's Avatar
    Apr 2012
    Utah
    Default Water softener pellets vs. crystals
    Which works better for water softeners?
    Pellets?
    Crystals (by this I mean the rock salt)?
    My guess is pellets because it's more expensive -- but does it really work better?
    Thanks in advance for your replies.
    Only a fool tests the depth of the water with both feet.
    ~ African Proverb
    Utah Soft Water
    Quote Originally Posted by kwust View Post
    Pellets?
    Actually, rock salt and crystal salt are different with rock salt being a lower quality--RE: dirtier. I would never use rock salt unless an emergency and only enough to hold you off till you get better salt.
    It may also depend on the softener. Most standard softeners use hard, iron-laden water in the brine drum so the quality of the salt isn't as essential. But if your softener uses treated water in the brine such as with twin tank or some high quality single-tank systems, then use pellet or cube salt only.
    Are you currently using a softener or making plans?
    Jan 2012
    California
    Rock salt quality is partially a regional issue and a QC issue. Salt is very heavy and expensive to transport so rock salt in one region of the country may be dirty, while oters may be very clean. Salt is rarely transported long distances. For the most part, salt is salt. I use rock salt, but our sources are very clean here in California. I have been to parts of the country where the rock salt will leave dirt residue after only a few bags. I would avoid salt that is dirty. If you do use dirty salt, be sure to clean and sanitize your brine tank annually. Let the brine tank run almost empty of salt, then clean it, add a 5 gallons of water, fill it with salt, and regenerate the system. it might not be a bad time to sanitize the resin bed as well.
    FYI, I used to sell millions of pounds of salt a year, we only used solar rock salt. Again, our source was clean, so it was not a big deal.
    Nov 2010
    Maine
    I'm not a fan of pellets but some folks have good results with them. We don't sell pellets though.
    Solar crystal is best because it doesn't have the problems or price pellets do. I would not use rock salt. Or 50 lb block salt.
  1. solar salt vs system saver pellets
    By bob tenthousand in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-12-2014, 11:02 AM
  2. Pool Chlorine Tablet vs. Chlorine Pellets
    By accord91 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-21-2010, 07:34 AM
  3. Heating with wood pellets
    By woodpellets in forum HVAC Heating & Cooling
    Last Post: 01-17-2009, 08:17 AM
  4. Wood Propane Wood Pellets
    By FrankMueller in forum HVAC Heating & Cooling
    Last Post: 07-21-2008, 06:09 PM
  5. Crystals in the toilet?!?
    By Moedde in forum Toilet Forum discussions
    Last Post: 12-22-2006, 04:57 AM
