Thread: High tank toilet very loud when flushed
    DIY Junior Member Jane Dibber's Avatar
    Apr 2012
    New York
    Default High tank toilet very loud when flushed
    We recently installed a high tank toilet. When flushed, a very loud (alarmingly loud) whoosh sound comes from the filler tube. I searched for "quiet flush toilets", but only came up with quiet fill solutions, where my issue is with the flush. Are there any options for limiting the noise from the filler tube has the water leaves the tank? many thanks!
    It sounds like it's working perfectly.
    You mount the tank high on the wall, and then when it's flushed, the water drops down with much force into the bowl.
    In Seattle, many of these were installed to force the water out into the bay when the tides came in. High tank, which dropped with great force pushing the waste and water into the bay.
    New toilets, where the tank is attached to the bowl, are called close coupled toilets. It's much easier to have a subtle flush when everything is so close.
    In Levenworth, I saw a high tank toilet flush so hard the water almost spun out of the bowl.
    Apr 2012
    New York
    Well, 4ft of gravity surely moves the water, and things appear to work fine, I was just wondering if there was a different fill tube design I could buy to replace the current one. toilet looks nice and flushes well but is as loud as all heck. I probably wouldn't have purchase the toilet if I knew it was going to be so loud.
  1. Master bath toilet splashes and bubbles when toilet in neighboring bathroom flushed!
    By redrover in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-08-2011, 01:45 PM
  2. Loud Hum from Water Pipe - High-Rise Condo
    By michellelukezic in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-13-2010, 05:30 PM
  3. High Tank Toilet Stopper
    By eorns in forum Toilet Forum discussions
    Last Post: 07-16-2010, 05:21 PM
  4. Tank leaks at water connection only when flushed
    By tbenton in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-09-2009, 07:11 AM
  5. Basement toilet floods whenever main floor toilet is flushed
    By NGalaxyTimmyo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-21-2007, 06:15 PM
