Page 1 of 2 12 LastLast
Results 1 to 15 of 27
Thread: Help identify resin and water softners
    DIY Junior Member scooby's Avatar
    Apr 2012
    Ann Arbor Mi
    Default Help identify resin and water softners
Size:  54.4 KBName:  0423121749a.jpg
Size:  45.3 KBName:  0423121849.jpg
Size:  35.8 KBI am having trouble finding out what kind of power head and resin i have in my water softners. I believe the one is a Fleck 2510 with a tank that is 10"x 47" and the other is a Fleck 3000 series with same size tank, this tank has no brine tube hooked up. The water coming from well has 25 grains, 425 ppm hardness, iron 3ppm and ph at 8.9 and 40-60 psi , there is a sediment filter inline before softners. The softners are at least 15 years old , they were in the house when i bought it ,and the water from the softners is ok but feel like the resin should be replaced some time soon. There are 2 adults living in the house and 2 bathrooms. I contated the name on front of covers and asked about resin and they said it was a "special mix" and wanted to come out tear the head off and take a look, he also wanted to be sure my wife was there when he was there so we could make decision together. So if anyone can help identify sofners and the type of resin that might be used in them would be great.
    Scooby7589
    Jan 2012
    California
    They are not 2510 valves. They may be 2750 or 2500 valves. Considering the age of these units, you have gotten your moneys worth especially considering how bad your water is. The reason they want your wife there is because they are sending a salesman, not a technician, once you told them they were 15 years old... new equipment time to them.
    I would recommend replacing the systems in the near future. You will be needing a complete valve rebuild, new media, new manifolds. The tanks and valve bodies are probably fine. Rebuilding these valves is relatively simple, I would rebuild/replace the injector assembly, replace the piston, seals, spacers, brine valve on softener, and replace the medias. The iron system "special blend" is usually nothing more than a couple of standard medias mixed inside the tank.
    Nov 2010
    Maine
    The bottom one is a Fleck 2500 and the top one is an Autotrol. Probably a 255 series.
    Apr 2012
    Ann Arbor Mi
    What would you recommend for resin in softner, and filter tank?
    Nov 2010
    Maine
    What are your water conditions?
    Apr 2012
    Ann Arbor Mi
    I bought a test kit from lowes , ph is 8.9 hardness is 25 grains at 425 ppm , iron is 3ppm. Not sure of the type of iron .
    Apr 2012
    Ann Arbor Mi
    When water comes out of spigot clear and stays clear after sitting for a while and no sulfur smell.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    The are both Fleck valves. One has a 3200 series timer and I'm not sure the series timer on the other unit but it's old. It sounds as if it is working if you are not getting iron staining. Test the house water and post the results.
    Apr 2012
    Ann Arbor Mi
    The house water after softner ph 7.5 , hardness 50 ppm , 0 iron , 240 ppm total alkanlinity, 0 copper , 0 chlorine no bacteria no lead
    Apr 2012
    Ann Arbor Mi
    The units are pretty old so i thought a rebuild would be a good idea but wasn't sure about what kind of resin to use?
    Nov 2010
    Maine
    I'm not sure that rebuilding the valves would be the way to go. With my luck, I'd replace the seals and a month later the motor would die. It might be a better plan to replace both valves. You can keep the tanks. Purolite standard mesh is fine for resin.
    Jan 2012
    California
    Tom, I am missing something. Am I looking at the picture correctly? They are both Fleck valves, the top one has no brine valve, and both have the old designer cover backplate. They are both probably 2500 valves, considering the meter location on the softener. Not likely a 2750 since that meter would be taller behind the valve. Where are you seeing the autotrol? I mean no disrespect, just curious if I am missing something. It would not be the first time.
    Nov 2010
    Maine
    You are right. For some reason I looked at the top picture and the timer looked like the old Autotrol to me but now that I look closer I believe they are both Fleck 2500's
    Jan 2012
    California
    Autotrol/Intermatic did use the 3000 timer on their older pilot controllers many years ago. That is a common timer so the mistake is an easy one. It is amazing how long this timer design can run without fail. I have seen these in service for over 30 years. The 3200 timer was a great replacement too.
    Apr 2012
    Ann Arbor Mi
    This has been a great help and I am starting to put the pieces together of what i have, but unsure of the resin to use for the iron sulfur removal, should i try to mix 2 resins together or will one type do the job. We have started to notice a sulfur smell from cold water supply on sink faucets but not on the tub or toilets. I betting the well will need to be cholorinated and wanted to do this first and then change resin in softner and filter tank. Thanks for all the feed back .
  1. Best Water Softners
    By biznitch15 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-24-2008, 02:52 PM
  2. Used water softener has a LOT of iron in the resin
    By snuffbox in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-20-2008, 06:35 PM
  3. In line water filters/softners
    By Time1992 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-14-2007, 08:28 AM
  4. Water softener media and resin
    By Alexdc99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-11-2006, 09:13 PM
  5. water softners
    By Dick Nelson in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-22-2005, 06:43 PM
