My well is fully functional, and the few tests I have had over the years show it is in great shape. But, I want to add a hand pump as a backup. To do this, I really need to know the water level to see if a shallow pump will work. I suspect it will. When I purchased the house, someone checked (somewhere) at the county, and it was something like 15 or 20 feet. From the picture, you can probably tell that this uses a jet pump.
I went to take the well cap off for inspection, and .. the bolts are really rusty. I am notorious for breaking bolts. I suspect these things just have to be turned once or twice (and not removed).
Do you have any recommendations for loosening these things? If I use oil, will I risk well contamination? Is a propane torch enough, and I am going to risk damaging anything?
A picture is worth 1,000 words. My well cap is about 3.5 feet below the surface, protected by a metal ring, and covered with a wooden "door" (more like a pallet).
Thanks for the suggestions.
