Results 1 to 5 of 5
Thread: Irrigation System well set up - Myers HJ100D
    DIY Junior Member rikmoor's Avatar
    Apr 2012
    Wilmington, NC
    Question Irrigation System well set up - Myers HJ100D
    First the data – I live on the coast in NC. I have a 2” well that was used for potable water for years until being annexed. I am converting this to an irrigation well. The well is 98’ deep. I recently installed a new Myers HJ100D – 1Hp pump and am getting 9 GPM at 35psi from an open end garden hose. With a 5 GPM sprinkler head attached, it is pumping at 55psi.
    So this seems like a low flow to me. The pump came with a regulator installed. Can I take this regulator off? Or do I just need to back the adjustment screw all the way out for the highest flow? It also has a pressure switch. Should I take this off? Adjusting these didn’t seem to make any difference.
    I’m trying to do what I can to get close to 20GPM for my irrigation system. And I want to get the flow maximized before I do my irrigations system design.
    Thanks in advance for any help!!
    Dec 2009
    northfork, california
    lose the regulator.
    Porky Cutter,MGWC Porky's Avatar
    Jan 2008
    Virginia Beach, VA
    Jet pumps require a regulator to hold at least 20# pressure on the system. . . I wouldn't remove the regulator! Depending on the pumping level (which will be hard to determine on a 2" well) 9 gpm at 35# is good for your pump.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    Apr 2012
    Wilmington, NC
    One thing I'm going to try is to remove the old pipe/packer/foot valve and replace it all. Didn't want to do this since it will be 100' of pipe but oh well. Seems to be the next logical step if I don't have something I can do on the pump itself. The well is 40 years old. No telling what condition any of that is. And my pump came with a new packer so I might as well send her down. Plus this will give me the opportunity to determine the water level in the well.
    Dec 2009
    Gotta a pile of jet pumps here and never saw anything resembleing a regulator on them.
  1. Need design system for Irrigation
    By DGM_Jakarta in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-05-2008, 04:37 AM
  2. Need design system for Irrigation
    By DGM_Jakarta in forum Irrigation / Sprinkler Forum
  3. Irrigation System Question
    By pumpkin30 in forum Irrigation / Sprinkler Forum
    Last Post: 08-16-2008, 05:01 PM
  4. well and irrigation system gone bad, need help!
    By Tedz241 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-10-2006, 11:16 AM
  5. Irrigation on house system
    By gahlen in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-22-2005, 06:15 PM
