Results 1 to 10 of 10
Thread: Culligan Gold/Silver Regenerating daily
    DIY Junior Member Dankon's Avatar
    Apr 2012
    Dallas, TX
    Default Culligan Gold/Silver Regenerating daily
    I have a Culligan Gorld or Silver softner. It regenerates every day. The #8 screen says "08". If I'm reading the manual right, this means it should regenerate every 8 days. I guess I could have the "soft-minder" - how can you tell if it is the soft-minder or time-clock model?
    Dec 2009
    Alaska
    Culligan used a few different controls on the gold or silver systems, so not sure about the number 8.
    Are you hearing it clean every night?
    Photo would help.
    The metered system has a part that is between the valve body and the bypass and there is a cable from there to the control head.
    Apr 2012
    Dallas, TX
    Yes, it cleans every night. I'll upload some photos tonight. Screen #8 is supposed to be the "regeneration interval", which should be Gallons (divided by 10) if unit has a soft-minder. If not, it should represent # days to regenerate.
    Dec 2009
    Alaska
    Sent a PM
    It is possible that if meter count is off, say 135 turns for each gallon for the correct count and if that number changes then the gallon count will change.
    A big sign for the difference between the metered unit and non metered is that the non metered or day will have the bypass up close and personal with the valve body, metered will have some space between the two for the turbin.
    The default day could have moved to 1.
    Is the display changing ? or is it stalled in one spot?
    Apr 2012
    Dallas, TX
    I don't think I have metered. Screen #8 (regeneration interval) says "8". Display is not changing.
    Dec 2009
    Alaska
    It is possible that the control board is locked up, as you should be able to step it through the different stages of the programing.
    Apr 2012
    Dallas, TX
    I am able to step thru the different stages of programming ok. On step# 8 of programming is the "regen interval". It now displays "08" for that. Here's a link to the owners manual: http://www.eculligan.com/support/gold2002.PDF The programming step I'm refering to is page 10, step # 8.
    Pretty sure it's an older Gold Series model without the flow meter. I have included a couple of photo's (sorry for the poor quality). Name:  IMG_0691.jpg
Size:  35.7 KBName:  IMG_0693.jpg
Size:  38.6 KBName:  IMG_0695.jpg
    Dec 2009
    Alaska
    If it is the metered then there is a cable going back to the out side of the valve body right at the bypass valve on the blue side of the handle.
    Send a pm, there is a manual that has more on that board, might need to be reset.
    Apr 2012
    Dallas, TX
    No cable from the blue side of the valve. I am new to the board - how do you send a PM?
    Dec 2009
    Alaska
    Right click on my nick and a list will show up, then click on the send message.
    Sorry that I did not get back to you sooner.
  1. Culligan silver not metering flow
    By Merc13 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-29-2011, 06:51 AM
  2. Culligan Gold series softener has constant overflow
    By kerby in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-14-2010, 06:46 PM
  3. Kinetico Sulfur Guard vs. Culligan Iron-Cleer/Gold Softner
    By marcopolo in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-21-2009, 01:09 PM
  4. thermostat on rheem needs daily resetting
    By Paulab in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-01-2009, 05:13 PM
  5. Daily Rocketboom
    By Mike50 in forum Computers and Stuff
    Last Post: 05-02-2006, 12:56 PM
