Results 1 to 5 of 5
Thread: well water pressure
    DIY Member ugabulldog's Avatar
    Nov 2007
    Northeast GA
    Default well water pressure
    How much psi should I have from well to tank, the same as my cut in and out settings?? If this helps, I have a submersible pump about 240' deep, well is about 380' from house, 1" pvc. Tank cut in at 30 psi, off at 60 psi. The reason I am asking is I have a pressure relief valve at top of well, it is leaking when pump runs, I have adjusted it all the way up to 175psi and it still leaks when pump runs.
    Moderator valveman's Avatar
    Mar 2006
    Either your pressure relief valve is bad, or you have a Cycle Stop Valve and the pressure relief needs to be moved to a point after the CSV.
    Feb 2011
    NW Ontario, Canada
    From another thread I was lead to believe that ugabulldog has a prefilter and a micronizer to aerate the water for iron filtering. A micronizer can be a significant flow restriction and can raise the pressure at the wellhead. How much, I don't know. If the PRV worked up until now and just recently started popping off, I would suspect it is either bad or the prefilter/micronizer is partially clogged.
    Nov 2007
    Northeast GA
    Hi LL, I cleaned the filter, it was very durty but relief valve is still leaking, can't really check the micronizer, but it is still sucking air....thanks again for your help. I might ry another prv or just cap off.
    Mar 2006
    Put a pressure gauge where the prv is and see what pressure you are dealing with.
  1. Water Softener On = No Pressure, Bypass = Normal Pressure?
    By jsarin1 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-08-2011, 04:06 PM
  2. Could my new pressure balance valve be reducing my water pressure?
    By JenJen in forum Shower & bathtub Forum & Blog
    Last Post: 02-22-2011, 06:57 PM
  3. Changing water pressure on house pressure regulator.
    By kskier in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2010, 09:20 AM
  4. High Water Pressure Spikes on Well with Pressure Tanks
    By RayMan in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-01-2010, 12:57 AM
  5. Water in well, pump working, can't build up pressure, but doesn't lose pressure????
    By bgnotaplumber in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-20-2007, 10:32 AM
