Results 1 to 6 of 6
Thread: Hot/Cold Reversed on Moen Single Handle Shower Knob
Hybrid View
    DIY Junior Member sixgun95's Avatar
    Mar 2012
    Scottsdale, AZ
    Default Hot/Cold Reversed on Moen Single Handle Shower Knob
    Had a plumber come by yesterday and he installed a new stem. Now the hot/cold is reversed. Really want the hot back on the left side. I read here that all you do is remove the handle and turn the stem 180 degrees? How do you turn the stem? Does it matter if I turn it clockwise or counterclockwise?
    Homeowner
    Jan 2010
    Alabama
    Quote Originally Posted by sixgun95 View Post
    yes remove the handle and turn 180 degrees with some pliers. Turn it either direction. You do not have to turn the water off. It is simple...dont try to make it hard.
    Mar 2012
    Scottsdale, AZ
    Got it, thks.
    Depending on the valve, you either turn the stem or the entire cartridge. If you pull the handle to turn it on, then you rotate the stem. If you turn the handle to start the flow, then you have to extract the cartridge and turn the entire thing 180 degrees.
    Mar 2012
    Scottsdale, AZ
    Just turning the stem did it, thanks.
    DIY Junior Member gere's Avatar
    Jan 2013
    Prince Edward Island
    Thank you so very much. Husband & I followed your advice and in a few seconds it was fixed. Didn't want to bother the plumber for such a small matter! This is my first time on this site and my compliments.
    gere
  1. Hot and cold reversed on Moen single handle faucet
    By justinren in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-11-2011, 06:25 AM
  2. hot cold reversed? single back and forth handle in kitchen
    By 68malibu383 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-13-2010, 07:06 AM
  3. Moen Single Handle shower- no cold water???
    By b00mstick11 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2010, 02:29 PM
  4. How to take out Moen Single handle rotary shower.
    By canadianexpress in forum Shower & bathtub Forum & Blog
    Last Post: 05-09-2010, 06:56 PM
  5. No Hot water from shower - Single handle knob
    By Mawk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-30-2009, 09:54 PM
