Results 1 to 3 of 3
Thread: Vanity drain fittings for remodeled bathroom
    DIY Member rfsmith48's Avatar
    Feb 2008
    Colorado
    Default Vanity drain fittings for remodeled bathroom
    Folks,
    Currently deep into planning for remodel of a small bathroom.
    New vanity location will place vanity drain on the centerline of the existing 3" vent for this bathroom and the adjoining bathroom. (Existing vanity is offset about 24" off vent centerline. Adjoining bathroom vanity is about the same distance off the vent.) Existing plumbing has a double y with the vanity drain lines going into the vent. Does someone make a double y with the drain fittings at 90 degrees rather than the expected 180 degrees?
    I can refit the vent with the new vanity drain below the existing y, but would prefer to keep the new drain on or close to to the existing drain grade.
    TIA,
    Rog Smith
    In less this is a pedestal situation, you can offset from the center of the lav by about 4" and still hit it. The p-trap has a swivel on it.
    They do make a double fixture fitting, but nothing oddball. You may have to use conventional fittings to make it up.
    If this is NOT a pedestal lav, use the existing connection, but with a "close" nipple and elbow. You can then offset back to the new drain location inside the cabinet.
  1. Plumbing issue in newly remodeled bathroom
    By SabrinaFlorida in forum Plumbing Forum Discussion & Blog
    Last Post: 08-10-2010, 06:34 PM
  2. Hot water to remodeled bathroom
    By krob8000 in forum Tankless Water Heater Forum
    Last Post: 01-19-2010, 02:17 PM
  3. Remodeled Bathroom Venting
    By LarryK57 in forum Plumbing Forum Discussion & Blog
    Last Post: 01-21-2005, 05:03 AM
  4. Remodeled Bathroom Venting
    By LarryK57 in forum Shower & bathtub Forum & Blog
    Last Post: 01-19-2005, 09:35 AM
  5. Remodeled Bathroom Venting
    By LarryK57 in forum Remodel Forum & Blog
    Last Post: 01-19-2005, 07:37 AM
