Coolul007
First, let start off by giving kudos to the help I received getting the old well started and going. I greatly appreciate all of the advice and best of all I was not steered in any wrong direction. Now for the present dilemma, When the well is not in use for a few days, rust appears, my guess is it is from the casing and or from the pipe attached to the submersible pump. The well is approximately 25-30 feet deep. I connected a "keystone" filter with a 20 micron insert, this did nothing to filter the rust. I did some research and saw several references to a D.E. filter, like ones used on swimming pools that "should" filter the rust. I had a Hayward D.E. filter on a pool so I am familiar with their use. Has anyone used this solution or have opinions?
