Results 1 to 10 of 10
Thread: Woodford hot cold water
    DIY Member Geo422's Avatar
    Feb 2012
    Cin oh
    Default Woodford hot cold water
    Hi I have an woodford hot cold water bib in my garage. Couple of weeks it got to leaking around the hot water stem . They are the 8 inch size so I replace the both of the stems with new ones that had new seals and everthing on them . After taking the old stems out and putting new ones in they seemed good. But now when the water is turn on cold or hot it leaks or rather shoots out from the hot side cold stem does not leak at all . Thanks George
    Depending on WHERE the water is shooting out, it may just be a loose or defective, stem packing.
    Feb 2012
    Cin oh
    It shoots out where the hot water stem is around that handle . If I turn on only the cold water it shoots out around the hot handle . Is there a better setup then this one? My garage is heated I keep it in the 40 in winter time . Thank you
    Depending on the type of stem seal, you either have to replace it or tighten it.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    A service sink faucet might work for you if freezing is not an issue. You can attach a hose to a service sink and it has a mixing faucet for hot and cold water... Many of the woodford outdoor hose bibbs are designed to be frost proof. When you shut the water off they drain out around the stem. There is a packing washer that seals this drain off when the valve is opened. Yours may be bad as HJ points out, on the hot side.
    http://www.webstaurantstore.com/t-s-...FcyP7QodszY1kg
    Feb 2012
    Cin oh
    Thanks just curious about one thing when both hot and cold handles are turned off there is no leaking at all but just as soon as the handle is turn on it leaks . Why? George
    Apr 2011
    NC
    Which woodford faucet do you have?
    http://www.griggindustries.com/page16.html
    The manufactuer has tech support people that know their products...have you called them? They'd probably know exactly what's the issue rather than someone who may never have seen that model before.
    Feb 2012
    Cin oh
    Model 22 Wall mount
    Apr 2011
    NC
    Default Check the packing
    The model 22 should not leak or drain out around the stem. I would take it back apart and make sure the packing is facing the proper way.
    http://www.woodfordfaucet.com/product6.html
    http://www.griggindustries.com/page23.html
  1. woodford hydrant
    By Rolfsi in forum Plumbing Forum Discussion & Blog
    Last Post: 10-10-2009, 01:31 PM
  2. Woodford 67C wall hydrant
    By mrproperties in forum Plumbing Forum Discussion & Blog
    Last Post: 09-19-2009, 02:49 AM
  3. Woodford tube removal????
    By jeffs in forum Plumbing Forum Discussion & Blog
    Last Post: 04-27-2008, 07:07 PM
  4. Broken Woodford operating rod
    By Woody in forum Plumbing Forum Discussion & Blog
    Last Post: 06-26-2006, 08:24 AM
  5. Leaking Woodford Model 17
    By yanchu in forum Plumbing Forum Discussion & Blog
    Last Post: 06-27-2005, 07:56 PM
