Results 1 to 10 of 10
Thread: Well pump setup questions
    DIY Junior Member Goonberry's Avatar
    Apr 2012
    Oklahoma
    Default Well pump setup questions
    I am new to wells and well pumps and hope someone here on the forum could provide some insight or critique what I am trying to do. I have a well on my property that was already there when I build the house and I would like to use it for outside irrigation only. Water level is about 20' from the top of the pipe (6.75" pipe with a 5" pipe inside). I dropped a string down and got to about 200 feet without bottoming out (ran out of string). I would like to keep the project as cost effective as possible, so I want to use a 4" submersible pump dropping it about 100 feet (1/2 hp 10-12 gpm. 2 wire) using 1-1/4" 160 psi poly pipe with a long brass barb connection with no safety rope or torque arrestor. I would size each of the irrigation zones for 10 gpm at 40 psi to avoid any excessive pump cycling.
    I would like to do this without a pressure tank? What type of pressure protection if any is needed? Could I still use a pressure swith with a tankless setup?
    I would have about 8 zones and water each zone for 30 minutes twice a week.
    Would a red lion/little giant pump be sufficient for this setup or are they junk like most of the box store brands?
    I have read hundreds of posts on the forum and know that there are numerous people on here with extensive knowledge and experience so any advice would be greatly appreciated.
    Jan 2008
    Virginia Beach, VA
    You're on the right track and yep Big Box store pumps are usually junk but cheap and they do work. I'd recommend installing a Pside-Kick. The Pside-Kick includes all that you will need to give you constant pressure for your irrigation system while extending the life of your pump. Go to http://www.cyclestopvalves.com/products.html to see the Pside-Kick. If you can't find it in your area contact Cycle Stop Valves they can assist you. NOTE: Don't purchase a VFD type pump!
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    Apr 2012
    Oklahoma
    Porky.
    thanks for the input. I have some budget constraint so I will procede without the pside kick and then hopefully add it in the future for a more stable pressure and less cycling of the pump
    Moderator valveman's Avatar
    Mar 2006
    If you can match all the zones to the pump, then use the pump start relay in the sprinkler timer box to turn the pump on and off. You can't use a pressure switch without a pressure tank.
    DIY Junior Member JPat's Avatar
    Mar 2012
    Johnsburg, Il
    Some type of pressure relief should be installed. When the zones switch you will get an increase of pressure and dead head the system against your sprinkler valves, over time they will fail prematurely due to the excessive pressure.
    Mar 2006
    Ditto on the pressure relief!!! It will help with spikes between sprinklers zones. But most important, it will keep the motor from burning up when the gophers eat the wires to the sprinklers, the timer didn’t know it and started the pump anyway.
    Apr 2012
    Oklahoma
    excellent. I will match the zones and install some type of pressure relief valve. No gophers around here just prairie dogs
    Apr 2012
    Oklahoma
    Running into a small issue when trying to find a well seal. The i.d of the top of the well pipe is 6-3/4", it flares out at the top. I am not worried about the well being sanitary but would like to attach the drop pipe to the cap and put an elbow on it to keep it all secure. I guess I could cut off the flare out at the top.
    Any ideas? what are my options. No pitless adapter on this.
    Name:  20120414_221819 (600x800).jpg
    Mar 2006
    Looks like just a steel coupling on top. But what is that blue thing in there?
    Apr 2012
    Oklahoma
    Its some sort of insert just shy of 5" ID. Not sure how deep it goes.
  1. Will this shallow well Jet pump setup work?
    By tuckerdog in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-28-2012, 01:52 PM
  2. Well Drilling and Setup Questions
    By milkman1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-09-2009, 08:39 PM
  3. Best Setup for Sump Pump and check valve
    By DanM in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-16-2009, 03:50 AM
  4. Submersible vs. Jet Pump Setup
    By jdoll42 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-08-2008, 01:00 PM
  5. Need Well Pump Setup Advice
    By chetwynd in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-07-2007, 12:49 PM
