Results 1 to 7 of 7
Thread: How to add tankless water condensate drain and softer drain to existing plumbing?
    DIY Member Killer95Stang's Avatar
    Mar 2012
    Southern CA
    Default How to add tankless water condensate drain and softer drain to existing plumbing?
    First.. let me start by saying the water supply plumbing is no longer like this. I ripped out all of the supply piping as part of my bathroom remodel, and will be re-plumbing everything from the attic. With that out of the way, the pic below shows the current layout of the drains and vents for the toilet and sink. Right behind the sink is a water heater closet where I will be removing the tanked water heater and installing a tankless unit. I will also be adding a water softer system a few months down the road.
    What I need to know is.. Can I cut the iron pipe above the sink drain tee, add a Sani-tee (abs with No-hubs) with trap and then a stand pipe in the water heater closet. I figure it will work like a washing machine drain stand pipe. If this can't be done, can someone lead me in the right direction? Thanks.
    Plumber jimbo's Avatar
    Well, that will work ok, and makes sense...but strictly speaking under the California plumbing code you can't do it. The pipe above the sink arm is a vent, and you can't put waste into a vent line. Also, you can't wet vent a bathroom with an appliance like a softener. You could add revent the sink around the softener tie in.
    Mar 2012
    Southern CA
    Thanks for responding Jimbo..
    I do want the drain to be done correctly! So... can you help me understand the proper layout for a separate drain for the softener? Is it something that I can handle? I've looked up "how to properly drain a water softer" but all I see are ways how not to drain it.
    Thanks... BTW.. I'm open to all suggestions.. even if that means hiring a plumber...
    The softener drain, because it is a "pressure flow" item can be connected below the sink, but not above it.
    Mar 2012
    Southern CA
    So I can put a Sani-tee below the sink drain, but then the water softener drain would have to be part of a sealed drain?... Or can I still configure a stand pipe in the water heater closet behind the sink?
    Mar 2012
    Southern CA
    Found this picture.. is this a correct way?
    conceptually yes, but your installation might be slightly different.
  1. Adding new sink drain to existing horizontal drain
    By Bob Lewis in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-01-2011, 08:16 AM
  2. Can I Tap Into Drain Pipe to Drain Condensate From High Efficiency Furnace
    By oskarjones in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-06-2010, 06:20 PM
  3. Using existing tub water/drain for sink
    By Fidget in forum Shower & bathtub Forum & Blog
    Last Post: 10-17-2009, 01:48 PM
  4. Connect shower to existing grey water drain
    By hatrick4467 in forum Shower & bathtub Forum & Blog
    Last Post: 04-28-2008, 04:11 PM
  5. Condensate Drain and no floor drain nearby
    By Lakee911 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-19-2005, 10:05 AM
