Results 1 to 15 of 17
Thread: Laundry Room. Sink and Washing machine on adjacent walls with stack at corner
Hybrid View
    DIY Junior Member bryankloos's Avatar
    Mar 2012
    MA
    Default Laundry Room. Sink and Washing machine on adjacent walls with stack at corner
    Hey Guys,
    I currently have a 4" soil stack running vertically from the 1st floor to the basement floor near the corner wall of the laundry room I am building.
    I want to plumb a sink and washing machine, both about 5 feet out from the corner of the room where the current 4" soil stack is.
    I'm wondering if I can tie into the 4" soil stack with a 4x4x2" wye. From there I would run another 2x2x2" wye horizontally and run drain down each wall. With this configuration, both the washing machine and the sink drains would tie together horizontally and then use a very short common 2" line to where they tie into the 4" stack. Is this acceptable, or do I need to have each drain (washer and sink) dump into the 4" stack independently.
    I would of course use 2" vents near the p traps on each drain which would tie into the existing 2" vent running parallel to the 4" soil stack.
    Any thoughts?
    Jan 2008
    Isn't MA one of those state that requires one to have a plumbing license?
    Normally when a horizontal branch drain runs into a stack, it is done with a sanitary tee.
    It would be uncommon to find an existing vent in a basement. What is it for/from?
    Plumber jimbo's Avatar
    Yes, unfortunately MA will not allow the homeowner to do this job. But we don't snitch here! We are concerned about the vent, but if I am not mistaken, for some years MA has required all new construction to provide a "future vent" in the basement for exactly this reason. Maybe that is what he has.
    Mar 2012
    MA
    Did I say I was from MA???? They dont let us do electrical here either Shhhhhhh.....
    The vent was from the prior washing machine drain which was in unfinished space.
    Quote Originally Posted by bryankloos View Post
    bryankloos
    DIY Junior MemberJoin DateMar 2012LocationMA
    The line that says LOCATION MA......that was the tip off about where you are!@ Unless you lied in your intro!!!!!!!!!!
    Nov 2010
    Maine
    I think that when you do your own plumbing in Mass, they make you swim with the fishes.
    Mar 2012
    MA
    I need to tie into the stack lower, as the current drain is too high for the laundry box.
    As the stack is about 6 inches from the corner wall, I thought it would be easier to tie both 2" drains together horizontally before dumping into the 4" stack, at a new 4x4x2 wye, which would be mounted a bit lower than the existing setup.
    I would run 2 vents, one from the sink side and one from the washing machine side up to the existing vent.
    I hope this is clear???
    Thanks,
    Normally, you don't want to share the WM drain line with anything else until it gets bigger.
    Mar 2012
    MA
    If thats the case, I guess I need two seperate ties into the 4" stack? That said, should I use wye's or sanitary tee's at the 4x4x2 location?
  1. Where to add washing machine standpipe to stack
    By jerry_johnson in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-21-2012, 07:03 AM
  2. Washing Machine Stand Pipe/Drop In Sink DWV stack question.
    By kittyarc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-10-2012, 04:51 AM
  3. Plumbing for Laundry Sink and Washing Machine
    By logan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-10-2010, 04:40 AM
  4. Washing machine / laundry tub plumbing
    By bradatkins in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-05-2010, 07:46 AM
  5. Washing machine & laundry sink venting
    By hoffmand in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-15-2010, 06:02 PM
