Results 1 to 7 of 7
Thread: Adding vent line for basement bathroom
Hybrid View
    DIY Junior Member zspinner's Avatar
    Mar 2012
    CT
    Default Adding vent line for basement bathroom
    Hi, I am installing a full bath in my basement and I am working on picking up a vent line from a 1st floor bathroom sink. I need to run the new vent line approx. 20 feet to where the 1st floor sink is. This also requires 4 direction changes (90 deg bends) to get from the new bath location up to the floor joist in the basement ceiling and then around pipes and other obstructions in the floor joists (through 5 joist spans) before I get to the existing sink vent location. Are there any restrictions on direction changes in vent lines before I tie into the existing 1-1/2"? Thanks.
    Jan 2008
    There are restrictions, the primary being that the pipe must have pitch to drain in any horizontal run, and cannot have any "jogs" in the line that would prevent complete gravity draining. Some areas also have limit to the length of any horizontal section to a percentage of the overall length of the vent. While there might not be a restriction to the number of bends, there should be one accessible cleanout in the line for every 135 degrees of change in direction.
    You should also consider that the 1-1/2" vent allows no room for expansion. If you wanted to add the laundry or another sink in the basement, you would need to run another vent through the roof.
    It is always best to locate a place in the house where you can go straight up from the basement through the roof. As an alternative, you can run straight up into the attic and connect to an existing vent there. Where there are no stacked walls to run a vent through, there often are stacked closet spaces where a vent can be run in a corner of a closet and boxed in after the plumbing inspection is completed.
    Aug 2009
    South*East
    You do realize that the vent must tie in above 6" above the flood rim of the sink on the first floor.
    John
    Sep 2009
    Seattle. WA
    You say "full bath", so I guess there is a toilet being vented, but a toilet requires a minimum vent size of 2".
    Your 1 1/2" vent won't fly.
    There are NO vent lines in the basement that you can tie your vent to. Unless you already have a sink or something down there which is vented, but in that case it would probably be 1 1/2" instead of the 2 you need.
    Jan 2008
    The OP falls under the IPC, under which an entire bath group can be vented through a 1-1/2" stack.
    I was under the impression he was planning to connect the minimum distance above the flood rim of the existing sink, but that might be a bad assumption on my part.
  1. Three questions about adding a basement bathroom
    By jmk823 in forum Plumbing Forum Discussion & Blog
    Last Post: 09-25-2009, 06:16 AM
  2. Adding bathroom to basement
    By philp in forum Plumbing Forum Discussion & Blog
    Last Post: 09-14-2009, 10:57 AM
  3. Adding new jet tub to 3 piece basement bathroom
    By tfrancis in forum Plumbing Forum Discussion & Blog
    Last Post: 01-31-2009, 05:18 PM
  4. Adding Bathroom in Attic-Wet Vent?
    By David Seebeck in forum Remodel Forum & Blog
    Last Post: 03-29-2006, 09:12 AM
  5. Adding Bathroom to Basement
    By ronanz in forum Toilet Forum discussions
    Last Post: 09-14-2004, 01:59 PM
