Thread: Vespin ii doesn't fit - supply line blocking access.
    DIY Junior Member Spacepod's Avatar
    Mar 2012
    Socal
    Default Vespin ii doesn't fit - supply line blocking access.
    Hi there,
    Love the site, very helpful.
    I have a new Vespin II with 14" rough replacing a Briggs unit. The water supply is about 4.5 inches off center, if that. It has a full knob on it, nothing fancy from the wall. Should I use a 12" rough and 90 elbow joint with a quarter-turn Dahl valve or get a qualified plumber to move the supply over to the left so I can use the proper 14" rough? Legroom is not an issue but I don't want the toilet too close to the tub, and I know the 14" rough is correct and I already bought the 14" Unifit adaptor.
    Floor is just linoleum, nothing fancy.
    Ideas?
    Thank you
    Pod
    If you will look at the previous thread, "Toilet water supply turn off too close to the floor", you will see where Terry added some valve options to my response to the question.
    Mar 2012
    Socal
    Default Thanks
    Hi there,
    I ended up having a plumber come out and move the supply line over more. This way I can use my 14" Unifit as-intended. The cost was the same as if I just had him install the 90-degree elbow and adaptor...service call + any parts so I went with the better option.
    Great forum here and thanks for the reply.
    Spacepod
  1. Toto Vespin II supply line fit confirmation
    By magnumip in forum Toilet Forum discussions
    Last Post: 11-17-2011, 01:21 PM
  2. Toto Vespin II supply line question
    By areefer in forum Toilet Forum discussions
    Last Post: 11-11-2011, 09:59 AM
  3. Vespin II supply line Q
    By rcevan in forum Toilet Forum discussions
    Last Post: 01-10-2011, 11:10 PM
  4. Vespin II Supply Location
    By George K in forum Toilet Forum discussions
    Last Post: 11-07-2010, 09:40 PM
  5. Toto Vespin Water Supply / other 14" options
    By C-Nel in forum Toilet Forum discussions
    Last Post: 03-30-2005, 04:53 PM
