Thread: T&P valve on Tankless Heater
    DIY Junior Member loaderman's Avatar
    Mar 2012
    BC
    Default T&P valve on Tankless Heater
    I have a Tankless heater, ever since I bought the house 1.5 years ago the T&P valve has been discharging slightly when you turn off a hot water tap. I was told this is normal. Is it?
    Now the T&P valve is leaking constant when you use hot water. The water temperature is not overly hot coming out of the relief vlave, I can hold my hand in a pail of it for a minute or so. Wanted to take a temperature on it but do not have a thermometer.
    The tank was at 50C and I turned it down to 40C and it leaks a lot less water but still does leak a little.
    We also had a power outage if that makes any difference, although we were on holidays, however 4 showers were taken and 3 loads of laundry done before it started to leak after we got back.
    Figuring I'll probably just change the T&P relief valve and see if that does it.
    Any other thoughts or ideas?
    I would change the T&P
    Sometimes they get something inside that prevents sealing.
    do you know the temp & press setting of the valve? is there any check valves in the system? it seems like it's narrowed down to a pressure issue. not overheating.
    Mar 2012
    BC
    Old pressure relief was 201f and 150psi(?) just going from memory, replaced it with the same and seems to be fine now.
  1. Good/Best tankless heater valve kit
    By jzz30 in forum Tankless Water Heater Forum
    Last Post: 04-20-2011, 02:39 PM
  2. Replies: 10
    Last Post: 04-26-2010, 08:09 AM
  3. tankless water heater
    By renajames in forum Remodel Forum & Blog
    Last Post: 06-05-2008, 09:25 AM
  4. tankless water heater
    By pman in forum Tankless Water Heater Forum
    Last Post: 05-14-2008, 11:50 AM
  5. tankless water heater
    By meckroth in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-23-2006, 04:42 PM
