Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Wet insulation on new Bradford White water heater a big problem?
  1. #16
    Aug 2009
    Midwest
    Quote Originally Posted by damselindistress3 View Post
    Dear HJ,
    Thanks for your input! I purchased a Bradford White 40-gallon gas water heater with a 10-year warranty (MI403S6FBN) and a thermal expansion tank and paid $1200 for the equipment and installation.
    Sounds outrageous to me for a tank with only 1" of insulation and a 0.59 factor. It is ~$450 dollar tank. (Plumbing work was cheap when I lived in Georgia a few years ago, lowest prices I've experienced although I mainly had drain work done.) Back when I thought I might have to replace the Whirlpool a few years ago I tried getting some estimates on Bradford Whites. Never even got a call back after calling a few listed BW dealers. Fixed the Whirlpool myself for free and scratched BW from the list when the other eventually fails.
    But there shouldn't be any damage to the tank from this connection leak, so BW has no obligation, and wouldn't anyway since the problem was a defective install.
  2. #17
    DIY Junior Member damselindistress3's Avatar
    Mar 2012
    Atlanta
    Thanks. Yes, after installation I got extended warranty paperwork from the plumber, and a 10-year warranty sticker (from BW) to put on the water heater. Are the two models (the "10" and the "6") the same water heater except for the warranty period? I was told that there was no physical difference between the two models.
  3. #18
    Yakima WA
    That's the standard gimmick on extended warranties. The make a ton of money on warranties. Usually the tanks last longer than 10 years, and even if it fails after say 8 years, all you have left is 2 years pro rated.
  4. #19
    Homeowner
    Jan 2010
    Alabama
    Sounds like you were treated fair to me and made the choice you wanted to make. Like with any extended warranty its useless until you need it and then it sure is nice to have.
    I hope you have goodluck with it.
  5. #20
    Aug 2009
    Midwest
    One comment about the foam. I've noticed on my water heater and some others (may not apply to BW) that there is some filler fiber/sheet type material around the lower panel and foam fill point at the top. I assume that it provides a sort of stand off for the jacket during foam insertion and prevents the foam from extruding out the edges. These are areas that I see as being susceptible to accumulating some water during servicing/installation. In my earlier post I was ready to state that there was no reason any dripping should be happening after several hours at temp, until I noted this material that is in place in addition to the closed cell foam.
  1. Is new Bradford White water heater too old?
    By VtaLady in forum Water Heater Forum, Tanks
    Last Post: 07-08-2011, 07:19 PM
  2. Leaking Bradford White Gas Hot Water Heater
    By Mark in Virginia in forum Water Heater Forum, Tanks
    Last Post: 03-29-2011, 07:58 AM
  3. Bradford White Water Heater
    By shawk22 in forum Water Heater Forum, Tanks
    Last Post: 01-18-2010, 04:59 PM
  4. Bradford White Water Heater ???
    By Master Brian in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-05-2009, 02:26 PM
  5. where can I get a Bradford White gas water heater to install myself?
    By gnatlee in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-09-2008, 04:14 PM
