Results 1 to 4 of 4
Thread: System won't shut off
    DIY Junior Member Yarbs02's Avatar
    Mar 2012
    Canon City, CO
    Default System won't shut off
    I have a system, not sure what brand, was already here when I bought the house.
    Went to get setup for the spring/summer, had to replace the PVB. Got that all squared away, turned the system on for the first time, ran through zone 1 cycle just fine, zone 2 cycle didn't have as much pressure, then shut off zone 1 came back on and won't shut off unless I close the water valve to the system. Reset the timer, unplugged the timer, turned water on, zone 1 came on, sone 2 is not on at all...
    Need some help to figure this thing out...
    irrigation tech. mike1059's Avatar
    Jun 2011
    Portland, OR
    it sounds like the zone 1 valve needs to be rebuilt or replaced. I usualy see this problem when a diaphram goes bad or a lot of debris has got into the valve.
    Mar 2012
    Canon City, CO
    For those of you that might have the same problem here's what I did.
    I took the cap and diaphragms off the selnoids and blew them out, made sure there was no debris stuck inside and made sure they got a good seal... Tried the system again... Everything works fine.
    Pretty much that is what we would have recommended!
  1. How to properly shut off one hot water tank in a parallel system?
    By joeyw in forum Water Heater Forum, Tanks
    Last Post: 09-09-2011, 06:20 AM
  2. Rural Water System: System Water Main, Meter Reading Overcharging, Leak Detection
    By Goldpenbkkpr in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-28-2011, 06:01 AM
  3. Replies: 17
    Last Post: 10-28-2010, 07:37 PM
  4. Re-locating an Aerobic Septic Tank System or use system as-is?
    By pearlbluevtx in forum Plumbing Forum Discussion & Blog
    Last Post: 02-08-2010, 09:50 AM
  5. No Vent system in home sewer system
    By bicycler in forum Plumbing Forum Discussion & Blog
    Last Post: 04-10-2009, 10:13 AM
