Originally Posted by
Dana
A 12 year warranty and reduced AC load in the land of 25 cents/kwh is good enough for me. Clearly YMMV.
The 50 gallon $1000 GE from Home Despot will pay for the $700 difference in price between that and a purty-good 50 gallon standard electric in reduced air conditioning + water heating cost WELL before the warranty period is up- probably in less than 3 years at HI electricity prices even in a 2- person water-sipping household.
How long can that "long history of failures" be, pray tell? (Given that they're ALL new enough to still be within warranty!) Got any references to point to?
Batch solar/passive solar is still not super cheap, about half the installed cost of active solar even for those without freeze protection.
But go ahead, show us the lifecycle analysis of both alternatives, based on 25 cent electricity and a HI location, and DO reference your sources, s.v.p. For simplicity, assume an air conditioning COP of 4 for the whole house AC, and an EF of 2 (rather than the measured 2.3), if that makes the math easier, and assume you replace the hybrid &/or standard tank on a 10 year basis, 20 years for the passive solar.
The fact that the hybrid removes more energy from the room air than it consumed from the power lines means you'd already need at least a 50% fraction from the passive solar + standard electric system just to match it for the hot-water heating power. If the COP of the AC is 2x that of the water heater, the reduced electricity use by the AC for that 50% of water heat is half, or another 25%. The batch solar end would have to exceed 75% of usage to almost-match the whole-house performance of the hybrid, and at those levels you have to design in heat dumping etc to avoid the steam explosions. You may able to support your assertions on the lifecycle cost analysis without some real systems and real data, but the lipstick on bathroom mirror math sez "No way, Jose!"
