Results 1 to 3 of 3
Thread: Green Wire Hanging Out Back of Dryer (4 Prong)
    Default Green Wire Hanging Out Back of Dryer (4 Prong)
    Setting up a washer and dryer. Dryer is 4 prongs. Green wire coming out of back about 3 ft long. It says external ground connector beside it. Do I need to ground this (say to the washer) or is it ok to hang out the back?
    Mar 2011
    Houston, TX
    Quote Originally Posted by Thewaltwhitmans View Post
    Yes, I would connect it, as the manual says, If your washer is within reach.
    The instructions on the dryer should tell you exactly what is needed. Do you have a 4-prong outlet for the cable? If so, then that ground might be needed internally. If you are trying to install a new washer (or stove) and only have a 3-wire plug, they'll allow you to do it with a 3-wire cord. When sold, the dryer or stove has the neutral and ground separated in the thing, each going to a prong of the 4-wire plug. If you only have a 3-wire plug, the ground and neutral inside need to be connected together. So, if you have a 4-wire plug, it is already grounded properly.
    Attaching the ground lead to something that is grounded, maybe the screw of the receptacle for the washer, may be acceptable. It is an extra safety, and (I think) you should be safe without it, but it doesn't hurt.
  1. Outlet ground prong orientation
    By apparentgenius in forum Electrical Forum discussion & Blog
    Last Post: 06-01-2012, 07:04 AM
  2. Question about new wire for washer/dryer combo: What do I need?
    By leejosepho in forum Electrical Forum discussion & Blog
    Last Post: 12-05-2011, 04:26 PM
  3. change two prong to three prong outlet
    By danl02026 in forum Electrical Forum discussion & Blog
    Last Post: 07-21-2010, 03:25 AM
  4. Installed 240v Dryer, used 10 gauge wire, 20 amp breaker-breakers flicking off
    By 87vertgt in forum Electrical Forum discussion & Blog
    Last Post: 10-17-2009, 07:37 AM
  5. Installing a Dryer 30 Amp power cord, 120/240 volt. what gauge wire?
    Last Post: 09-30-2009, 10:15 AM
