Results 1 to 12 of 12
Thread: Wiring a workshop 3 wire question
    DIY Junior Member 83mulligan's Avatar
    Mar 2012
    Michigan
    Default Wiring a workshop 3 wire question
    Hello All,
    I have an issue here. I've been reading on this forum a bit and have come to realize I need 4 wire to wire an outbuilding and service panel that meets code.
    Well, here is where I'm at. A few years ago i ran a trench 30 inches deep to my outbuilding. I put in a 2" conduit with a satellite cable, a pex water line and a 10 guage 2 wire with ground. I wrapped the three components in pipe insulation and pulled it through a section of conduit at a time and glued the pvc up. I think its about 60 ft. from house to outbuilding. It was a really tight fit and was a real pain.
    Well, now its 2012 and I'm ready to start building my woodworking shop. I read that in need a 3 wire with ground. My question is this. There is a Romex line running to the outbuilding now that is on one 20 amp circuit in the house panel. its burried along a different path and not in conduit. It is grounded to a rod and it is 12 guage. Can I disconnect it from the main inside and use the wires at the outbuilding as a 4th wire or does the difference in gauge kill this idea?
    I'm a complete novice when it comes to electrician work so please forgive me for messing up terminology.
    Steve
    Jun 2007
    North Carolina
    No .
    As I understand it, if you only have one circuit in the outbuilding (and no subpanel), you could use what you have. Only if you need or want more circuits off a subpanel to include 240vac stuff, would you need a 4-wire connection.
    Mar 2011
    Houston, TX
    No .
    Really ?
    A reason would have been nice.
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
    Really ?
    Code requires a 4-wire (2-hot, neutral, and separate ground in one cable) to be able to use a subpanel. IOW, the wires must be routed together, not separated.
    DIY Member kevink1955's Avatar
    Nov 2011
    L.I. New York
    And you cannot put CATV and a water line in the conduit with your electrical service, start diging for a second conduit.
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    Quote Originally Posted by kevink1955 View Post
    No kidding. I'm surprised he did not plumb in a line to the beer keg while he was at it!
    Mar 2012
    Michigan
    This is what I thought, thankyou.
    Mar 2012
    Michigan
    Quote Originally Posted by Homeownerinburb View Post
    I quit drinking 5 years ago. The old me most certainly would have.
    Mar 2012
    Michigan
    Why not the water line. I thought burried conduit was considered a wet environment anyways? I think I'll pull the sat cable out and pull a fourth line through for the sub panel. This would work. I suppose I could just not get it inspected as well.
    Mar 2011
    Houston, TX
    I don't see why not.
    Beer Keg line also.
    Don't forget the compressed air line.
    Mar 2011
    Long Island, NY
    Quote Originally Posted by 83mulligan View Post
    The way you want to do it sounds like maybe you should have the water line terminate in the sub-panel with a hose bib
    I assume you are joking, as I am too
  1. C wire question
    By dgosssigep in forum HVAC Heating & Cooling
    Last Post: 02-22-2012, 04:54 PM
  2. Wire splicing question
    By charp in forum Electrical Forum discussion & Blog
    Last Post: 07-24-2011, 01:13 AM
  3. Wire size question
    By jparrie in forum Electrical Forum discussion & Blog
    Last Post: 10-20-2008, 04:46 PM
  4. Green Plumbers workshop
    By Terry in forum Plumbing Forum Discussion & Blog
    Last Post: 06-12-2008, 06:38 AM
  5. spliced 10 -3 wire question
    By capnwill in forum Electrical Forum discussion & Blog
    Last Post: 09-26-2007, 07:00 AM
