Results 1 to 5 of 5
Thread: Gravity septic system
    DIY Junior Member Suthnr's Avatar
    Mar 2012
    Cabor Arkansas
    Default Gravity septic system
    So i just got into my new house and for some reason my master toilet keeps backin up!! I had it snaked and worked fine for about half a day, so i got a new one and put it in an im still havin probs! I looked in the insp port outside yesterday and no water was backed up and it rained real bad yesterdayand today so can that cause a toilet to get backed up?? It is only my master toilet i need help thanks
    If you had it snaked and it still backed up, WHY did you replace the toilet instead of calling the "snaker" back? IF it were a toilet problem, which would NOT have taken a day and a half to happen again, that would be the easiest thing to correct. If it is drain line problem, then it was NOT snaked properly in the first place. There are problems which can cause a single toilet to not operate, but have NOTHING to do with that toilet.
    Mar 2012
    Cabor Arkansas
    Default Snake it?
    Is there a snake that can go all the way to the septic? When whoever had the house before me put it all in he never leveled the ground so it has standin water on the septic and all the lines. I dug trenches yesterday to c if it would help, can that cause a prob as well?
    The drain line to the septic should be essentially dry (well, it will be damp) unless something is draining into it at the time. To achieve this, it must slope downwards with no flat spots or dips all the way to the tank. Yes, standing water in the drain line is a problem, and you need to correct that. What can be a major problem is if the septic tank is higher than your lowest line going into it or there's not enough height offset to allow you to maintain the required minimum slope (depends on the size of the line, but most like at least 1/4" per foot - large lines can work with less). If that's the case, you will need to add a basin and an ejector pump. But even then you want gravity to help as much as possible and the line should not have any low points to collect crud.
    Dec 2009
    northfork, california
    My idiot snaker guy rammed all the crud just to within 4" of the tank tee, and announced that the tank was plugged.
    His snake and brain was too short - opened the tank with the pumper there and stuck a stick in the pipe and got a big shower of crud. Pumped it anyway, but didnt really need it.
  1. Gravity fed spring water system
    By LaneH in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-01-2012, 10:13 PM
  2. Gravity fed water system help
    By extendedpath in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-20-2011, 09:23 AM
  3. Gravity Feed System in Chile
    By Melvinac in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-06-2009, 06:48 AM
  4. Sprinklers for Gravity Fed System
    By Green Pastures in forum Irrigation / Sprinkler Forum
    Last Post: 07-24-2008, 01:11 PM
  5. Air release ? in a converted gravity system
    By xjmllc in forum HVAC Heating & Cooling
    Last Post: 10-26-2007, 09:15 AM
