Arachia
1 hp shallow well jet pump for home shallow well 70-140'. pump was giving 60-70psi easy at first but nearby orange groves keep drain the local wells. Have to shut off pump when they water for frost or during dry season then reprime a day later to stop over heating. we have one bladder tank but no resivor tank. hot water tank is in house also shut off when well shut off. now pump can only barely reach 50, so we lowered the shut off by turning the big spring. the bladder tank doesn't seem to have much water in it but it does seem to have air, but don't know how much is suppose to be in that tank of air or water. has the running dry for a hour or 3 before we noticed the well went dry damaged the impeller or is the problem with the pump they are only about a year old or could it be a problem with the well.
what has been done so far:
adjusted shut off, reprimed pump, redid any screw on pipe seal with plumbers tape that seemed to have an air leak pipe seal have to be redone if the well goes dry and the pump gets hot until no water drips and no air leak can be heard
the pump is a goulds pump itt jplus jet pump
model c48a95a06-j10 b0865194
rpm 3450
amps13.016.5
the guys that installed it decided that it the well didn't need the jet adapter and did the nonjet install.
rpm 3450
amps13.016.5
