Results 1 to 10 of 10
Thread: tamper proof receptacles
    DIY Junior Member monkeybrains's Avatar
    Nov 2010
    new york
    Default tamper proof receptacles
    Is any one brand of tamper proof devices better than another? Are the devices you find in the big box stores(brand for brand) typically the same that you would find in an electrical supply house? Any recommendations would be greatly appreciated.
    Thanks,
    Jim
    Making something "tamper proof" would require an enclosure of some kind. The devices, i.e., switches and receptacles, are not tamper proof by them selves, at least depending on what you mean by "tamper proof".
    There are good, better, best available in any line (and you may not have access to all of those at the big box store - check an electrical supply house and the manufacturer's website to determine what's what). More money buys you a more robust internal construction, not necessarily for their shutter mechanism, but for the electrical contact size and thickness. Depending on where you live, they began to be required in 2008.
    Plumber jimbo's Avatar
    hj you are a little behind the time on this one! The electrical code for new contstruction now requires most receptacles to be tamper proof ( interpret this as child-resistant). All the major brands make such devices. They have a shutter across the blade openings, and will only open when a blade is inserted into BOTH at the same time. A child trying to poke something in to one side....it does not go.
    Just an example: http://www.globalindustrial.com/p/el...FYub7QodDDr1xw
    I do not consider "childproof" the same a "tamper proof". My interpretation of "tamper proof" is "vandal proof". But they have been designing "childproof" outlets for decades. Some of the earliest ones "interlocked" the hot and neutral slots mechanically so you had to stick objects into both openings before the power would flow.
    Electrical Contractor Jim Port's Avatar
    Aug 2009
    Maryland
    The code uses the term "tamper resistant" for the devices with the shutters to prevent things like keys being inserted into the receptacles.
    NOTHING is vandal proof! Vandals have a school that teaches them how to deal with "vandal proof" gizmos!
    Dec 2009
    northfork, california
    Incorrect, 2 large german shepherds in the yard make all the surroundings 'tamper resistant' and 'vandal proof'.
    And that sign with the revolver AND a dog that says mind the dogs AND the owner, sends all vandals to the guy with a parakeet next door. For best results, hand paint the sign with a bad brush on the end of a rusty 55 gallon drum.
    I had a trail on a property that the dope growers were using, and one of those full size body targets full of holes and a note about trespassers on it soon solved the issue.
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    Dogs are easily managed.
    Mar 2011
    Long Island, NY
    Quote Originally Posted by Homeownerinburb View Post
    You mean you'd poison the dogs so they wouldn't shred you to pieces? That's cruel
  1. Tamper resistant options for 2 wire supply to receptacles?
    By weaver in forum Electrical Forum discussion & Blog
    Last Post: 02-18-2011, 04:02 PM
  2. Tamper resistant receptacles - remodeling project
    By chuck b in forum Electrical Forum discussion & Blog
    Last Post: 01-31-2011, 12:16 PM
  3. tamper-proof angle stops...argh!
    By mylifeisazoo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-23-2010, 11:59 AM
  4. Any Tamper Resistant Tank Lids for Toto?
    By Firemark in forum Toilet Forum discussions
    Last Post: 08-25-2009, 12:59 PM
  5. code compliance - GFCI and tamper resistant
    By beekerc in forum Electrical Forum discussion & Blog
    Last Post: 10-23-2008, 03:18 PM
