Results 1 to 5 of 5
Thread: low water well pressure
    DIY Junior Member thunderchief's Avatar
    Mar 2012
    Crescent, Oklahoma 73028
    Default low water well pressure
    i have a shallow well 22 ft. 1hp jet pump, square D pressure switch set at 40/60 psi and 10 gal bladder tank, i'm able to build pressure up to 60 psi then pump stops but when we use water to the house or try to water lawn pressure drops to 20 psi and will not build any higher, what could be the problem.
    Thanks Bill
    Moderator valveman's Avatar
    Mar 2006
    Sounds like you are getting all the water there is in the well. Maybe your well screen is plugged up.
    Mar 2012
    I have been told that the well casing my be fill with sand that came thru the preferated hole in the casing, if so i would i get it cleaned out,
    Mar 2006
    You will need to fix the hole in the casing to keep the sand out.
    Jan 2008
    Virginia Beach, VA
    I have a cousin that lives North of Crescent! Does your well have a 4" casing and is it under a windmill? It sounds just like my cousins.
    As Valveman says first you must repair the hole in the casing to prevent the sand coming in.
    Is this a one pipe (shallow well) or two pipe suction (deep well) setup? If it's a shallow well the well point may be plugged. If it's a deep well hookup it may have a well point on below the jet assembly and it may be plugged. In either case you are getting a limited amount of water to the pump.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
  1. Water Softener On = No Pressure, Bypass = Normal Pressure?
    By jsarin1 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-08-2011, 04:06 PM
  2. Could my new pressure balance valve be reducing my water pressure?
    By JenJen in forum Shower & bathtub Forum & Blog
    Last Post: 02-22-2011, 06:57 PM
  3. Changing water pressure on house pressure regulator.
    By kskier in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2010, 09:20 AM
  4. High Water Pressure Spikes on Well with Pressure Tanks
    By RayMan in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-01-2010, 12:57 AM
  5. Water in well, pump working, can't build up pressure, but doesn't lose pressure????
    By bgnotaplumber in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-20-2007, 10:32 AM
