Results 1 to 5 of 5
Thread: Kinetico K-60 is discharging constantly.
    DIY Junior Member TinaB's Avatar
    Mar 2012
    Baltimore
    Default Kinetico K-60 is discharging constantly.
    Our Kinetico K60 is constantly discharging water (just a steady trickle). It is going through 40 lbs. of salt every few days. We have replaced the piston parts and the float assembly.
    How old is it? Tan or black tanks? Who is "we"? Did you disassemble it or did a local dealer? Did levels 2 and 3 separate? It could be a seal that is leaking through.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Quote Originally Posted by TinaB View Post
    The drain seals may be bad. You would have to take the unit apart in order to replace them. If you need a parts breakdown, e-mail me @ affordablewtr@aol.com and I'll send then to you.
    Mar 2012
    Baltimore
    The softener is old but not sure exactly how old. The tanks are tan. We means my husband. It wasn't regenerating on its own and he tore it apart and replaced some parts. It regenerates on its own now but there is a constant trickle and we are going through about 40 lbs of salt every 2 to 3 days. I am hoping he can fix it since it is a $150 service charge plus parts. My husband is extremely handy but the water trickle has him stumped. Thanks for all of your help.
    I wonder if you can take a sample of the dripping water and have it tested to see if it is hard or soft? That would help narrow the problem. Is it possible to do this?
    If it is hard, then you have a problem with the drain valve.
    If it is soft, there are any number of causes, some of which are relatively easy to fix.
    In the older units like yours, levels 2 and 3 were 'molded' together. If there is a small warp between the two, water will be short-cutting and seeping through or by-passing water ports. This would require this section to be replaced with separate levels (2 & 3).
    Is your household water pressure less than 20psi?
    Whatever you do, DON'T lubricate o-rings or seals with Vasoline or any other petroleum product.
  1. Toto is constantly filling, not quite sure how to fix
    By momof6 in forum Toilet Forum discussions
    Last Post: 06-08-2011, 12:21 PM
  2. Replies: 16
    Last Post: 11-16-2010, 11:14 AM
  3. Need HELP! - Rainsoft water softener discharging brine outside next to my foundation.
    By Chris Stuart in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-06-2010, 09:50 PM
  4. Kenmore Water Softener - Discharging via Overflow Line
    By pgdaboys in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-10-2010, 02:56 PM
  5. Sump Pump discharging onto lawn
    By kay79 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-07-2009, 03:39 AM
