Results 1 to 7 of 7
Thread: Bolt-up shower drain?
    General Contractor dx's Avatar
    Jul 2005
    Michigan
    Default Bolt-up shower drain?
    Does anyone make a drain for an acrylic shower base that bolts up like a garbage disposal? some type of arrangement with screws and a collar?
    Existing shower base, I have access from below but not enough clearance to tighten the normal 3" nut in place.
    I am aware of the Wingtite but prefer a more conventional drain with the rubber sleeve and castle nut connection to the drain pipe. Also not thrilled with the Wingtite silicone, would prefer a flange with a gasket.
    quote; Also not thrilled with the Wingtite silicone, would prefer a flange with a gasket.
    If it has a gasket, the gasket belongs on the BOTTOM of the shower and you still need silicone, or putty, between the flange and the shower base.
    Jul 2005
    Michigan
    Thank you Hackney. That's exactly what I was looking for.
    HJ, I see the Sioux unit above can be used with either putty or a gasket (top side). I'm OK with either, just don't want silicone because I don't want to glue the flange to the acrylic base. I want to have it easily serviceable.
    Plumber jimbo's Avatar
    I would not worry about a shower drain being "easily serviceable". If it doesn't last the life of the shower, there will be nothing easy about THAT!
    Jul 2005
    Michigan
    Jimbo, not so sure about that. The existing unit is about 15 yrs old and just started leaking. Regular ABS no-caulk drain with the big hex nut. Appears that leak was caused by the nut loosening from repeated flexing of the shower floor (base) over the years. Fortunately it used a gasket on top so it came out easily. I'll fix the floor flexing but still want to give myself a plan B
    Jul 2005
    Michigan
    OK, after further research I found an even better drain than the SiouxChief. The Davke3000:http://www.davke.com/
    Same idea, but also available in a no-hub so you can connect with a Fernco, which will allow a little flex in the system. This should accommodate minor movement of the shower floor without stressing the parts.
  1. Best Toto for bowl cleaning and bolt to drain pipe
    By alternety in forum Toilet Forum discussions
    Last Post: 11-07-2010, 04:34 PM
  2. Iron toilet drain, no flange, 1 bolt disintgrated, other rusted on?
    By eva01 in forum Toilet Forum discussions
    Last Post: 03-09-2008, 04:22 PM
  3. Plastic Oddities Bolt-on Tiled Shower Drain
    By smhowell in forum Shower & bathtub Forum & Blog
    Last Post: 08-02-2007, 08:22 PM
  4. Dropped a Flange Bolt Down the Toilet Connection Drain
    By typesh in forum Toilet Forum discussions
    Last Post: 09-18-2006, 07:25 AM
  5. Bolt came loose on drain
    By jadnashua in forum Shower & bathtub Forum & Blog
    Last Post: 03-24-2006, 04:12 PM
