Results 1 to 3 of 3
Thread: Heat on to 1 zone with no thermostat installed???
    DIY Junior Member wyro's Avatar
    May 2012
    NY
    Default Heat on to 1 zone with no thermostat installed???
    Last night the heat in my bedrooms came on. I removed the thermostat, no change. Went down to the basement and changed my zone valve head (TACO) and still have the same issue? What else should I look for?
    The boiler is an old weil Mclean the two zone valves are TACO 571-2. Heat has been off for several weeks if that matters?
    Jan 2009
    The zone valve is stuck in the open position- whether that's field-fixable without replacement remains to be seen, but the theory of how it operates is well described in the manual, and may help figure out how it failed, and whether it's reversible/repairable.
    May 2012
    NY
    I was hoping not to have to pull that valve out and drain the boiler... Oh well, I'm off work tomorrow and I'll pull it out.
  1. 2 zone system-no heat upstairs-Boiler doesn't fire when that zone asks for heat
    By MrBostn in forum Plumbing Forum Discussion & Blog
    Last Post: 10-13-2012, 08:33 AM
  2. thermostat for second zone doesn't control boiler?
    By HerHandyMan in forum HVAC Heating & Cooling
    Last Post: 02-23-2012, 06:36 PM
  3. Converting a manual switch heating zone to a thermostat heating zone
    By breilly629 in forum HVAC Heating & Cooling
    Last Post: 03-12-2010, 01:04 PM
  4. Replies: 1
    Last Post: 02-04-2009, 11:59 AM
  5. Little heat in one zone
    By joslinm in forum HVAC Heating & Cooling
    Last Post: 11-23-2008, 11:51 AM
