Results 1 to 12 of 12
Thread: water heater shelf life question.
    DIY Member u.s.coins's Avatar
    Mar 2012
    Pennsylvania
    Default water heater shelf life question.
    i have a water heater that i bought about 8 years ago but never used it. it is a 40 gallon gas and is still in the box! i had a leaky t&p valve on my present tank and i thought i was going to have to change it but instead i only needed to change the valve. anyway, i was figuring i'd need the new tank so i had it delivered but never had to hook it up yet! i wondered if it would spoil setting around all that time in my basement. i have it sitting on a sheet of black plastic.
    steve
    Since it's been in the box, it should be fine. It takes water to start the rust process.
    I'm not sure when the FVIR requirements started, but if it's a gas WH, it may no longer meet code. If electric, not a problem. If you were to put in a gas WH that didn't meet the current codes, you may have a problem with the inspection. Doesn't mean that it couldn't work right. There were new rules on preventing a gas WH from igniting flamable vapors from stored, leaking chemicals nearby that forced a new burner/air intake design awhile ago.
    Plumber jimbo's Avatar
    FVIR was July 2003, so you are close. Does it have a door to light the pilot with a match, or does it have a sparker?
    The FVIR requirement is just to keep idiots from blowing themselves up. The only problem with your heater is that the factory warranty has expired, but normally you would not need it anyway.
    Aug 2009
    Midwest
    If it is pre-FVIR, having that burner assembly on hand, new-in-box, is a big advantage...well, at least for those who aren't idiots that pour gasoline around their water heaters.
    As long as water (as in condensation from humidity fluctuation and temp cycles) hasn't been getting into the tank it should last indefinitely.
    Mar 2012
    Pennsylvania
    thanks terry.
    Mar 2012
    Pennsylvania
    yeah it's the match type. the good ol' fashion kind.
    While FVIR may be overkill, if you pulled a permit, the inspector may give you grief since it's what, 9+ years since the requirement changed. As to whether it should work...yes it should.
    Dec 2009
    northfork, california
    Put it on a 18" tall box to eliminate most explosive vapor issues.
    Aug 2009
    Midwest
    Quote Originally Posted by ballvalve View Post
    But then you have to build an 18" tall shelf next to it to put your gasoline and paint thinner on!
    Dec 2009
    Har har.... but paint thinner and diesel only burns with a wick in it, and gasoline falls to the floor. Same for propane. The sure fire way to blow up a water heater is spraying laquer big time in the room.
    I would sell it on craigslist and buy a sparker, or add somehow outside combustion air to the unit.
  1. Does a water softer shorten the life of your water heater?
    By 13jerry in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-30-2012, 07:48 PM
  2. question on water heater venting (orphaned water heater)
    By harveymasons in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-23-2010, 06:11 AM
  3. Hot Water Heater Life Span
    By smitty52 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-01-2009, 09:12 AM
  4. starrow shelf
    By Fitz in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-25-2005, 11:57 AM
  5. Hot Water Heater Life Span
    By bendhamma in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-05-2004, 10:52 PM
