Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: i have a lap-top with a loose power plug cable
    DIY Member u.s.coins's Avatar
    Mar 2012
    Pennsylvania
    Default i have a lap-top with a loose power plug cable
    hello all. i have a power cable that has become very sloppy at the plug in the back of the lap-top. if i would change the power cable would this remedy this problem? it has become worn to the point where it sometimes falls out of the female fitting in the computer back where it is connected. i've had this lap-top for maybe 6 years.
    is the female fitting in the computer the trouble or the cable end itself? and if it is the fitting in the computer can this be replaced? it's a dell inspiron 1501. thanks for any advice.
    steve
    Mar 2011
    Long Island, NY
    Quote Originally Posted by u.s.coins View Post
    is the female fitting in the computer the trouble or the cable end itself? and if it is the fitting in the computer can this be replaced? it's a dell inspiron 1501. thanks for any advice. .
    steve
    Try another power adapator plug that fits your laptop to see if the problem is in the laptop or your adaptor's plug. Most likey, it is the recepticle in the computer. I think if it were the plug, it would be obvious. My Dell laptop is a studio, and has a round plug from the power unit
    Mar 2012
    Pennsylvania
    Quote Originally Posted by BobL43 View Post
    if the problem turns out to be in the laptop, is that repairable? thanks.
    Mar 2011
    Long Island, NY
    Have you tried calling Dell's tech support line? They'll be able to tell you that answer and the cost too.
    Mar 2012
    Pennsylvania
    no, i thought i'd see here, first, if anyone else has had this experience. Name:  3Devil.gif
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    I took apart my mom's dell laptop and resoldered the power plug. it is possible. sometimes, especially computers, use multi layer circuit boards and if the power connector took a big hit instead of just the solder joint breaking, it may be a lost cause if it broke the board.
    Mar 2012
    Pennsylvania
    i'm not sure i am being clear with my problem. it is NOT the cord i am talking about. i am referring to the female fitting at the back of the laptop that the power cord plugs into. i am wondering if that has gotten sloppy over the years, from use and now it's not fitting tight anymore. and if that is the trouble is THAT part repairable?
    Jun 2010
    USA
    that is what i was talking about, the female receptacle itself. yes, it mounts to the pc board with solder, and it can come loose over time. your female receptacle can also become worn, and not make contact with the male plug. if that happens, you can try taking a dental pick or something like that and rebending the metal 'tang' that makes contact to the outer metal part of the male jack. not sure what else you could mean if you were not referencing either above, which is with the laptop itself, and not the power cord/jack.
    Mar 2011
    Long Island, NY
    If you are not very handy, I think the last thing you want to do is open up your laptop. If you were, you probably would have done so by now. Why don't you give Dell tech support a call and see what they can tell you. Anything is repairable if you want to pay for the labor and necessary parts if they are still available. I'm not sure, but they may talk to you for free. In any case, they won't bite you on the phone.
    Mar 2012
    Pennsylvania
    thanks all. i'll call dell or dump it at a shop. maybe i'll pry open the ol' wallet and spring for a new updated laptop.
    Mar 2011
    Long Island, NY
    At 6 years old, I guess it couldn't hurt to get a new one, except for your wallet. Does it work well enough to be able to copy all your data, etc. from it?
    Mar 2011
    Houston, TX
    The Connector can be replaced.
    It most likely has a switch built into it. You would need to get the correct replacement.
    Some times you can bend the Outer Metal contact tab in, so it holds better. But you need to remove the battery before trying, just for safety.
    Some connector have a split center pin, that you can spread apart for a tighter fit. (again removing the battery first)
    Same goes for the power adapter side. Just unplug the adapter from the wall first.
    Unless you can do the work yourself, a new laptop may be cheaper. But it would be a shame to trash a working computer, for such a minor problem.
    Good Luck.
    Mar 2012
    Pennsylvania
    i should have mentioned right out of the gate but didn't. in addition to the loose fitting power cable, the battery doesn't hold a charge longer than a about an hour, that's why i plug and unplug the power so often. please don't hate me. with this news then i guess i should go shopping for a new unit.
    Mar 2011
    Long Island, NY
    Here's a new Dell Laptop that looks decent for the money; its $699 on sale at Costco (if you are a member):http://www.costco.com/Browse/Product...uctsInCategory
    Mar 2011
    Houston, TX
    I was going to ask about your battery life but I did not.
    Battery packs can get expensive, Never buy a used one. They are sold used for a reason.
    Normally you can get a much better computer for about half of what that one cost you.
    You may want to check out Fry Electronics for a nice computer at a good price.
    Http://www.Frys.com
    if you are not a Costco member, Frys may beat their price anyway.
    Bob, Owns Costco and I own Frys.
    ...April Fool...
  1. Cable or Jet?
    By Nate R in forum Drain Cleaning
    Last Post: 01-09-2010, 07:01 AM
  2. Proper install of power lead cable for suntouch mat
    By bobcatm in forum Electrical Forum discussion & Blog
    Last Post: 11-04-2009, 07:07 AM
  3. No 6 AWG Cable
    By devans175 in forum Electrical Forum discussion & Blog
    Last Post: 09-12-2009, 06:33 PM
  4. Cable Drain (long cable needed)
    By dick2222 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-11-2009, 07:03 PM
  5. To plug or not to plug into a GFCI outlet
    By DIY in forum Electrical Forum discussion & Blog
    Last Post: 04-15-2009, 04:13 PM
