Thread: Drake Differences & 11" rough-in Qs
    DIY Junior Member TG284's Avatar
    Mar 2012
    Default Drake Differences & 11" rough-in Qs
    After a lot of reading here, it looks like the Drake is probably my best option for compact size & my 11" rough-in requirement.
    Are all drake cst743 round models created equally (newer, older, Eco 1.2, 1.6)? So if I buy from somewhere with older stock or the latest batch, does the 11 to 10 7/8" rear clearance likely still apply? Ive found a few spec sheets with different rear #s, just want to confirm.
    Might any of the Aquia models or newer contemporary looking/smaller tank units work with the 11"?
    Thanks Guys
    DIY Junior Member re8's Avatar
    Mar 2012
    Philadelphia
    Default More on Drake and 11" rough-in
    I've seen on this forum that the Toto Drake can make do with a 10-7/8 rough in.
    So does that mean that if I measure 11" from the wall to the bolts of my current toilet, then I'll have only 1/8 of an inch to spare?
    If so, I better make sure my measurements are accurate!
    At 11" you only have an 1/8" to spare.
    The horn is 2-5/8" going into a 3" drain. There is some room to fudge a bit at that point. But......you won't know for sure what you have until the bowl is pulled.
    The Aquia fits at 11.5", but also can be ordered with a 10" bowl CT412MF.10 that works at 9.5"
    The Drake CST744EF.10 works at 9.25" too.
    Mar 2012
    Thanks Terry & All, after finalizing tile im now working with ~10.5"... So 10" rough in it will be
    Am I correct in finding that the Drake 10" is NOT offered in round, only elongated? Any other shallower depth 10" toilets that i've overlooked?
    I am a click away from ordering the Aquia 10" (CST412MF.10), I like the narrow tank and even though it is elongated, a 27.5" depth. Any other significantly shallower toilets, or ones that tuck the wall best for 10.5"RI that come to mind, lmk.
    Thanks again!
  1. 10 7/8" rough? Cadet 3 or Drake cheaper?
    By busmechanic in forum Toilet Forum discussions
    Last Post: 03-04-2011, 04:33 PM
  2. Best flushing toilet for 10" rough-in? TOTO 10" Drake
    By catorgs in forum Toilet Forum discussions
    Last Post: 11-01-2010, 12:12 AM
  3. Replies: 2
    Last Post: 07-03-2010, 05:33 PM
  4. Can I use TOTO Drake II for 10" Rough-in?
    By Ukrainetz in forum Toilet Forum discussions
    Last Post: 03-24-2010, 10:05 AM
  5. toto drake with 12" -> 10" rough in adapter?
    By lairdwd in forum Toilet Forum discussions
    Last Post: 08-20-2006, 06:08 PM
