Redoing a shower pan and leaving the rest can cause problems. Its always best to tear the whole thing down and start over. It could be anything though... Grout failure, bad seal around your faucet trim ring, preslope issues etc...
When the pan was redone did you replace the whole pan or just the tile? The weep holes could be clogged forcing water to saturate the mortar bed and out a crack somewhere.
