Thread: Check valves what ones work the best?
    DIY Junior Member Rod M1's Avatar
    Mar 2005
    Michigan
    Default Check valves what ones work the best?
    I'm going to install a shallow well jet pump and looking for a check valve the spring presser on most are very light maybe 1 pound. The plumbing store sells a 5lb check valve that is PVC instead of brass for much higher cost are these the way to go?
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    I like my footvalves/check valves to be brass. I have never had much luck with platic valves.
    I think the Flowmatic brand is #1 with Simmons #2. Both are made in the USA to my knowledge. Also you can get them in stainless now for some applications.
    You don't need a high spring pressure, the PSI of the water is all the pressure you need.
    Moderator valveman's Avatar
    Mar 2006
    Pressure closes the check valve. The spring has little to do with making a good check valve. You certainly don’t want a check with a heavy spring on the suction side of the pump (too much restriction). You could get away with it in the discharge side, but it is not needed.
    Repeatedly slamming a check valve closed, caused by cycling the pump on and off, can destroy even the best check valve. Reducing or eliminating pump cycling can even make a cheap check valve last a long time.
    Dec 2009
    northfork, california
    Even a kid can look inside a typical spring loaded check valve and see a flat - usually plastic disc, with a spring behind it, and wonder, gee, how does water churn its way around that blockage. A ball cone check valve is like an airplane wing, and is a solid ball cone that takes a big beating without fail.
    A good rule is step up one size also for your check valve. http://www.grainger.com/Grainger/APO...KT9?Pid=search You can find these for less, surplus center has SS ones that I bought tons of, and have never had a failure in 20 years of installations.
    And another- http://www.lakecountypipe.com/34-Apo...-6110401-.aspx
  1. Check valve doesn't work with Solar Drainback system.
    By politics123 in forum Solar and Geothermal Water Heating Forum
    Last Post: 11-02-2011, 02:26 PM
  2. Multiple check valves
    By paullyboy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-17-2008, 01:39 PM
  3. check valves
    By tickridgescott in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-05-2006, 09:32 PM
  4. Double Check Valves .............. Again!
    By tvl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-11-2006, 08:29 AM
  5. two check valves?
    By KQ2N in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-19-2005, 07:12 AM
