Results 1 to 3 of 3
Thread: water pressure drop?
    DIY Junior Member djwehr's Avatar
    Feb 2012
    Washington
    Default water pressure drop?
    I recently replaced my PRV and it is set at 70 psi. when we open a faucet, etc the pressure drops to 40 psi is this normal or could something be wrong? prior to the old prv going bad we never noticed any drop in pressure while showering. Upon taking the old prv apart i notice a large portion of one of the rubber o-rings was missing. could this be blocking flow in our meter? not sure what to do any suggestions?
    Sep 2009
    Seattle. WA
    How about a little more info as to: how did you set the PRV to 70 psi? How and where are you measuring the 40 psi?
    Pressure in an open pipe (faucet open) will always go from zero at the opening to some higher value at the source.
    The greater the flow, the lower the pressure readings will be.
    Aug 2009
    Midwest
    It's not normal, but is a sign of a failing PRV. With my old PRV even tiny flows would drop the pressure 15-20 psi. I'm talking about setting the flow so low that water was just barely coming out of the faucet in a stream vs. a nearly continuous set of drips. If you see high DP at very low flows then it isn't a system DP problem, but something specific to the new PRV/install.
    What was the failure mode of the old PRV? Was it letting through full line pressure all the time?
    If you have your PRV model number, you can actually look up the performance curve and determine what the DP should be for the flowrate being drawn. It should be low for normal shower flowrates (unless you are running multiple 2.5 gpm shower heads.)
  1. Water pressure drop after remodel?
    By stanh in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-08-2011, 06:07 AM
  2. Drop in Water Pressure?
    By bperillo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-09-2010, 01:28 PM
  3. Water pressure drop
    By kevin schuhl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-12-2009, 01:52 PM
  4. Water Pressure Drop
    By Siegfried in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-03-2007, 06:45 AM
  5. Why Would Water Pressure Drop?
    By nipandgab in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-24-2006, 08:10 AM
